Topic: Accordion door latch removal (Read 127 times) previous topic - next topic
In the process of removing the accordion door latch.
Took out the two obvious screws, but it’s still firmly attached to the wall.
Is there another attachment that I need to undo or is this another example of Lazy Daze gluing it in place never to be removed?
Dave
2017 TK
Re: Accordion door latch removal
I removed mine. The latch came off easily. No adhesive.
jor
09 27' MB
10  Suby Forester
Can the "fat" part of the latch be pried off?  There may be a screw underneath.
It may have an adhesive strip holding to the wall, forcing it off may damage the plastic coating on the paneling.
You may want to use a product like Goof Off to soak behind the latch before attempting to remove it.
https://www.lowes.com/pd/Goof-Off-Pro-Strength-Remover/999959857?cm_mmc=shp-_-c-_-prd-_-pnt-_-bng-_-LIA_PNT_133_TS-Sanding-Sundries-Surface-Buckets-_-999959857-_-Online-_-0-_-0&ds_rl=1286981&msclkid=feb04127b0e513bc786e23d69b6bbf2a&gclid=feb04127b0e513bc786e23d69b6bbf2a&gclsrc=3p.ds
