AC run capacitor failure August 01, 2022, 03:18:54 pm Enjoying a 2005 LD Twin/KG for many years. 1st AC issue yesterday. Run capacitor failed on compressor side. The capacitor is a 20+10mfd 370v on a Duo-Therm model 600315.321. No info on parts at Dometic. I guess it is too old. Having trouble finding a match to purchase. Any help would be appreciated.
Re: AC run capacitor failure Reply #1 – August 01, 2022, 03:33:04 pm Hi Geoff; We just had a long thread Two days ago that concluded with a place to find those hard to find dual capacitors. AC Not Working about reply #49. This kind of info is what the search feature is for. A drop down menu off of "Community" and 'Search' will help you answer many questions. RonB
Re: AC run capacitor failure Reply #2 – August 01, 2022, 04:23:03 pm RONB, thanks for the quick reply. Guess I got in a hurry when I could not find data or match on the web. Looks like some good reading and info in that string. I’ll spend some time there. What is your opinion on how much larger Capacitor is Ok to use as I do not find a 10+10 Mfd?
Re: AC run capacitor failure Reply #3 – August 01, 2022, 04:37:23 pm After blowing our LD's A/C start capacitor and then having the control switch burn up, both caused by hard starts in low voltage conditions (brown outs), I installed an RV soft start. It eliminates the high amperage surge on startup.It should be a standard part of rooftop A/Cs. It's great for when the A/C needs to be run at night, reducing the noises when the compressor starts up.Larry
