Topic: Valence, Shade, Butcher Block (Read 486 times) previous topic - next topic
Made a few minor mods after reading a bunch of threads on what you guys have been doing to your LDs.
Butcher Block: Didn't really care for that metal tent thing over the range. Followed in the footsteps of the LD giants and went for more counter work area.
Removed the valences: We did this in our last rig and really liked the feeling of spaciousness. I especially like the feel in that great panoramic view room in the back.
Entry Shade: I didn't think we had a shade but when I removed the entry door valence, whatdayaknow, there it was! I picked up a different color black out. Might build a little valence. Still thinkin' about that.
jor
09 27' MB
10  Suby Forester
Re: Valence, Shade, Butcher Block
We really like the wood cutting board we put on our stove top. However I am extra vigilant when it comes to verifying  flame is off before putting the board back on the stove. One time a burner was on simmer and I thought it was off when I put the cutting board back on the stove. While I was doing other tasks I noticed a burning smell and realized my blunder. It was just a good  scorching. I was horrified when I realized what what a disaster could have ensued if I had left the coach for a period of time.
Ever since this lesson we make sure the flame is off AND visually confirm all burner knobs are in the off position.
2003TK
"Butcher Block: Followed in the footsteps of the LD giants and went for more counter work area."
Jor
If you like butcher block and want more counter work area you might consider this...
That fiberglass fold down shelf extension to the left (?) of the sink is a prime place to secure a cutting board and work space. Purchase the appropriate (to fit the space) size hardwood butcher block and attach it to the existing fold down brackets. Or there are more substantial brackets to be had on Amazon.  :D
Nice work, Jor! Like you, I removed the valances, and it made a big improvement in the view.
Yes, nice indeed!  We also wanted more counter space so found a thick bamboo? cutting board at a Homegood's store.  It weighs so much, we simply put some rubber matting on top of the metal cover and friction holds it in place even when traveling.
I like your solution. My board is thick and heavy so I bet that would work for us. Sure would have been easier!!! ;D  We'll give mine a try and if we don't like it, we'll knock off your idea! Thanks for the tip.
jor
09 27' MB
10  Suby Forester
[quote author=Lazy Bones link=msg=243934 date=1657398616
That fiberglass fold-down shelf extension to the left (?) of the sink is a prime place to secure a cutting board and work space. Purchase the appropriate (to fit the space) size hardwood butcher block and attach it to the existing fold-down brackets. Or there are more substantial brackets to be had on Amazon.  :D
[/quote]
Like this.
Factory brackets still in use after almost 20 years
Jor.   I’ve wanted to remove the valance over the door so I could replace the shade.  I haven’t tried to remove the few screws that are visible.  If you have a few minutes, could explain how you removed it?
Like this.
Factory brackets still in use [after] almost 20 years
Couldn't have said it better, Larry. Pictures speak louder......   ;D   ;)
I didn't take a photo with the valence in place but there are just four screws which are not difficult to get at. Here are the locations of the two on the right and there are two placed identically on the left.
I think you should be able to remove your shade without removing the valence. Just give it twist on the left side I think, pull that side out and it should just come right out.
jor
09 27' MB
10  Suby Forester
Jor, you’re right.  We were able to easily remove the shade, repair loose threads, and clean it.  Since the shade still works, we going to just reinstall it tomorrow.
We will probably still remove the valence to recover it with matching fabric that we’ve already replaced.
At any rate, thank you Jor.
I removed a valance as an experiment. It did increase the view but it also increased the drafts coming off the windows on very cold nights.  The glass and aluminum frames let a lot of cold and/or heat into the interior.
Shades that fit tightly to the valances help prevent the cold air coming off the window from easily penetrating into the interior.
In some windows.
With some of the windows, removing the valance allows viewing of the interior from the outside, not ideal if you value privacy.
Little off-topic, worn pleated shades have holes where the strings pass through that wear, slowly becoming big enough to see through from outside, at night when the interior is lighted. Another privacy issue. Roller shades do not have this problem.
Since we camp year-round in various conditions, we decides comfort was more important than a slightly bigger viewing area, YMMV.
Question for those that removed the valences. On the rear window of a MB, how do you secure the roller blinds against the slanting feature of the back window ?
Thanks, Merry Christmas Eve As well.
mar 🌴❤️🌺
Current 1 and only: 2003 LD Mid Bath 26.5
2017 Winnebago Minnie Winnie TT
2011 Dutchman Colorado 32' TT
2011 iCamp 14' TT
1985 Coachman Catalina 32' RV
We have the slanted bath window in our FL and have not removed valances. However, the valance plays no part in securing the blinds at the bottom. It was different in our '83 FL, which had roller blinds.
I installed a couple of carpeted aluminum angles. Work great.
jor
09 27' MB
10  Suby Forester
Nice Greg!
Going to give that a try.  Might even attach the rubber matting to the cutting board.
Dave
2017 TK
