Topic: Leveling (Read 303 times) previous topic - next topic
Leveling
Here's a newbie question for you old LD hands. We've had several class A motorhomes all of which had automatic leveling systems. Consequently, I'm not familiar with manual leveling. Also, our class As were a monocoque design (no frame rails) so we were always careful about getting the rig twisted. Raise/lower front, back, either side.
So my question is: Is it OK to raise or lower just one corner? The previous owner of our rig generously threw in a bunch of those orange Lynx deals so I've got the stuff I need I think. Thanks.
jor
09 27' MB
10  Suby Forester
Re: Leveling
Yes to your original question.....we've used the stick-on level (one for side to side, one for front to back) with success for years
2013 31' Silver Twin Bed
Semi-retired 6/21....
Re: Leveling
A bit off but can someone help me with the copy paste issue on trying to get LD posted for sale
I am trying by my phone...how to copy paste.
Thanks
hank_87 us@yahoo.com
Hank
1986 22' Chevy G30 Multi-Plan
2000 Ford v10 23.5 Front Lounge
Re: Leveling
Whichever corner(s) are low, try to raise them with your blocks.  Here’s a basic video I found but there are probably many more on YouTube:
https://www.youtube.com/watch?v=GlqwB-zAUKk
Re: Leveling
We have the lynx levelers and I use the level mate pro. It'll get me spot on every time.
Jon
Re: Leveling
jor
Your chassis is pretty stiff, so twisting is not an issue. However, proper bi-directional leveling will assure less shifting as you move about the rig, and more accurate leveling.
Re: Leveling
When we level with boards and ramps, I nearly always have to level either both front tires (2) or both rear tires (4).  Or we needed to level the driver’s side tires (3) or all the passenger side tires (3).  So it’s either front or back or left and right.  I can’t remember needing to level just one front tire or just one set of the rear tires.  If we did, I can’t remember.    So I doubt we’re putting any stress on the frame.
Re: Leveling
And, given a choice, I’ve found it’s easier to level the front tires rather than the rear. Also uses less blocks since both duallies should be supported.
Re: Leveling
OP here. Went with 2x8 ramps. Cut them at 48" but decided to go down to 45" for ease of handing in and out of the compartment. One thing I'm getting used to is the shorter height of the exterior compartments in a class C. Sure wish LD had figured a way to keep that spare in the back!
jor
09 27' MB
10  Suby Forester
Re: Leveling
Installing the LevelMatePro was very easy to install and made leveling trivial during my ten weeks on the road this summer.
I bring up the app on my iPhone as I’m getting ready to back into a campsite and I get real-time data on my state of level, so I know the most level spot at the campsite, and where I need leveling help, if any, before I put the RV in park.
I’m not ultra picky about level, anything 1.5° or less is fine by me, even let it go up to 2° occasionally, preferring the front end to be a bit higher to allow Lake Newton to drain.
Dave
2017 TK
Re: Leveling
Thanks for the report on the LevelMate product, Dave.  It seems to work in my trial use but good to hear it worked well on your travels!
Jor, your blocks look great!
Re: Leveling
Jor,
Your ramps are very similar to the ones I built. In addition to the wooden ramps, I may also use plastic ramps I purchased at the mothership when we picked up our ‘15 RB.
I’m posting photos of my ramps. Originally, I placed plastic dowels to prevent the ramps from skirting about when I used to back onto the ramps.
Now I no longer use the dowels but instead use my drill driver to screw the ramps together when needed. Also, I no longer back onto the ramps and now prefer to pull onto them. Much easier.
Depending on the corners to be lifted to level, placing blocks at any one corner is fine. Camp sites can be awkwardly tilted. Sometimes I’ll raise front and back tire sets on one side. I can not recall leveling opposite front and rear corners.
In regards to blocks under the dually’s, many of us will place ramps on both tires on a dually set on either corner. Also, I have found that spacing these two sets of ramps three fingers apart allows me to perfectly align both tires on the ramps and thereby avoiding any side to side overhang which can put undue stress on the tires inner belts.
A huge benefit to my method is that I can back off the ramps (whether back or front tires) and slide them out and have them ready to reinsert when I return to the site after dumping or heading into town. It’s made getting back to level quick and easy.
Hope this explanation wasn’t confusing.
Re: Leveling
Kent, your level solution was much prettier than mine last week.  ;)
My wheels:
2012 Jeep Liberty
Re: Leveling
I'm a believer., I had to do something under our last class A one day and I only had two ramps (2X12s) available. So I put that baby up with one tire on each side. Big mistake. The tires ballooned out llike they were going to pop. Abandoned that plan immediately!
Kent, you're getting a little higher than I and if you hit that top level, you'll be in record territory. Of course, if you overshoot your mark, it's a long way down!
Deb, I'm thinkin' you need to patent that setup before someone knocks it off and gets rich on your idea!
jor
09 27' MB
10  Suby Forester
Re: Leveling
Jor,
  You said, “Kent, you're getting a little higher than I and if you hit that top level, you'll be in record territory. Of course, if you overshoot your mark, it's a long way down!”
This is another reason I pull onto rather back onto the ramps. I went off the deep end while backing onto the ramps at Serrano CG and pushed the 8x8 post and tweaked my rear bumper at bit. Kind of a love tap but I gave no reciprocation to that post.
Another reason that I pull onto the ramps (the dually’s especially) is due to the front tires turning slightly and putting my rear tires a bit crooked as I backed onto ramps in Yellowstone. It was after many unsuccessful attempts that I decided to pull onto the rear ramps. Made it in the first attempt. Took several years to learn that lesson.
Re: Leveling
Another reason that I pull onto the ramps (the dually’s especially) is due to the front tires turning slightly as I backed onto ramps in Yellowstone. It was after many unsuccessful attempts that I decided to pull onto the rear ramps. Made it in the first attempt. Took several years to learn that lesson.
I’ve gone back and forth on my first season on backing onto vis pulling onto my yellow plastic camco trilevels.
I’ve decided backing onto them is the right way for me because the damage is less if I forget about the levels when I leave (or have to leave fast in an emergency).   Granted, I have yet to have an instance where I have had to back onto the ramps repeatedly.
Dave
2017 TK
Re: Leveling
Guess I'm going to be that guy ..... <smile>
Leveling is for the comfort of the refrigerator.   According to the LD manual if you, the human, are comfortable then the refrigerator is fine.  We, LB and I use the Graduated Scale Level Stick On levels.  Put them on the Engine dog house cover.   Set them up to match the level of the frig.  We are happy if the level bubble is within 2 degrees.   We've been using the big red ramps we brought at the factory.    After five plus years have not had any problems.   We have boondock camped all over this great country.
glen
