Seeking Wall Filler Suggestion June 19, 2022, 09:51:39 am We are working on our 2005 LD RB and are getting ready to paint the inside walls. We've taken down the valances and some other fixtures and have a number of screw holes that we want to fill before we prime.Not having worked on a caravan before, we're not sure what product to use. We presume sheetrock compound, one of our favorite solutions for in the house, would not work.What have people used successfully to patch small holes?
Re: Seeking Wall Filler Suggestion Reply #1 – June 19, 2022, 10:25:56 am Hi Peter; I've used this to fill holes. It does shrink just a little as the vehicle evaporates. https://www.lowes.com/pd/DAP-Plastic-Wood-4-oz-Natural-Wood-Filler/4013497 I also keep this on hand. More versatile and dries dark gray. Amazon.com: J-B Weld 8276 KwikWeld Quick Setting Steel Reinforced Epoxy -... Once mixed in small quantities, it sets up in a few minutes. Dries hard enough to sand in about 15 minutes. RonB 1 Likes As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Seeking Wall Filler Suggestion Reply #2 – June 19, 2022, 01:20:41 pm If you were 2005 midbath has the same textured white wall panels as my 2003 did, white spackling is a good filler. Get the kind that's lightweight, because it shrinks less when drying. If the color doesn't match perfectly, you may need to mix up a little bit of touchup paint and then dab it on with the end of a mostly dry-bristled brush. 1 Likes As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
