Topic: Garmin Power (Read 248 times) previous topic - next topic
Garmin Power
I’ve been trying to figure out ways to clean up the power leads for all the gadgets that reside on my dash.  I relocated the Garmin over to the passenger side corner so as to be compliant with California law.  Previously it was in the middle of the windshield.
That presented the problem of how to get power without having unsightly wiring draping down and on top of the dash.  Inside the glove compartment there is a 12V power receptacle.  To use it, you need to have the glove compartment lid open which is inconvenient.  I was able to pop the receptacle out and remount it on the passenger side lower kickplate using a 1/2” pipe bracket.  From there, I routed the Garmin power lead underneath the rubber door gasket along the edge of the plastic dash so as to be not very noticeable.
Re: Garmin Power
Great idea!
Didn’t realize there is another outlet in the glovebox, will look next time I’m inside.
I assume that outlet goes to the chassis, not the house.
Dave
2017 TK
Re: Garmin Power
Apparently not as there is power with the key off.
Re: Garmin Power
Nice and clean looking job Greg, but I’m afraid it wouldn’t work for me.  My old tired eyes couldn’t focus way over on the other side of the cab to view the map.  Of course you have a lovely navigator sitting beside you to look at the map and give you directions 😘
- John
Re: Garmin Power
Good job and a productive idea.   My preference is to have the GPS on the left side.   I'm concerned with looking away from the road to view GPS on the right side.  Each to one's own.
dog Zeke
Re: Garmin Power
I have a gray dash mat.  So the wires for the TST readout, Scangauge and GPS, that are all micro USB run under the mat to the left edge.  Down under the rubber door seal edge, into the under dash area, where I added 12 VDC connectors, cigarette lighter sockets.  The access panel just pulls off. (not easily)  One for the Garmin, and double plug in for the TST and Scangauge.
    So Greg, that California law is for window mounted devices, and is particularly aimed at cell phones. Even cell phones running mapping/GPS routines.  Not blocking your view is a good plan, but my GPS dashtop mount only blocks my view of the hood. The 3x5" GPS is in line with the view down the road.
   Because early in my ownership when I put in a different radio, the one Ford power point runs on the chassis battery, and the other one runs on my house batteries, along with the CB and radio.  The keep alive memory power for the radio comes from the chassis battery.   The power point from the chassis battery is on all of the time, but the Trik-L-Start keeps that from being a problem anyway.   RonB
Re: Garmin Power
"Inside the glove compartment there is..."
Glove Compartment??? How quaint, right up there with fender skirts, tonneau covers and curb feelers! Lucky you!
Re: Garmin Power
Steve S, I know your just teasing but what else do you call it?  Is there a new name for the glove compartment?  I see that the cigarette lighter has been rebranded as a 12v accessory 😉
- John
Re: Garmin Power
The name is cool... but I feel slighted, I never got one and wish I had!
Re: Garmin Power
I’m sorry, I thought you were kidding.  I never knew the older Fords didn’t have one.  I wonder when they started putting them in???  I know the ‘48 Chevy I learned to drive on had one.  It also had a starter button on the floor to get it going too 😊
- John
Re: Garmin Power
It's unknown how this will work for me.  Should be OK as long as my Navigator is onboard.  The good news is, I didn't make any changes that aren't reversible.  I wish I had the electrical skills that Ron and others on this forum have but since I don't, I try not to tap into any wires unless absolutely necessary.
I really wanted to mount the Garmin on the driver side but I use the hood edge as a reference for position in the lane and the Garmin would block my view there, plus getting power on that side is more complicated. That's my story and I'm sticking to it!  :-X
Re: Garmin Power
Gregg said, “ I use the hood edge as a reference for position in the lane”.
When LD built our ‘15 RB, they added a microphone on the dash edge centered with the top of the steering wheel. I’ve found the mic to be a perfect sight for the center of the lane.
It helps a lot and is so small it’s almost invisible most of the time.
Re: Garmin Power
Kent, I have that as well but hadn't thought of using it as a reference.  I'll check it out next time I drive the rig.  Thanks!
Do you remember what that microphone is for, I forgot!
Re: Garmin Power
Gregg,
The mic is for hands free phone calls. Hook your cell to the radio via Bluetooth and answer calls using the mic.
I’ve used it once with success. I’d have to read the radio manual to figure out how to use it again. There are less cumbersome hands free options for sure. The mic is pretty handy for my lane navigation.
Not quite hands free though. Still gotta keep hold of the wheel.
