Topic: Replaced Ford TPMS with TST-507 & Borg valve extensions (Read 380 times) previous topic - next topic
I just replaced the Ford TPMS system with a TST-507 system and had Borg valve extensions installed.  There were several factors in my decision to change out the TPMS.  Here are the main reasons:
- Ford’s system didn’t measure temperature.
- It doesn’t monitor the toad’s tires.
- It can’t be used with Borg valve extensions.
- It would be expensive to replace with another Ford sensor when the sensor or batteries go bad.
- The system is awkward to use.  I have to leave my trip screen with things I care about like miles and mpg, then several clicks later I get to the TPMS screen and that’s all there is to see.
The one downside to having the Ford TPMS sensors removed is that the onboard computer now complains about either low (0 psi) pressure or that the sensor is not paired.  But there’s an answer for that too at the end of this post.
So last night I removed the wheel simulators and this morning I went to Fast Tire in Coarsegold.  I went there because its only a few miles from where I’m camped and I heard good things about them.  I brought along the Borg DL1FCFR chrome valve extension kit I bought plus one extra front valve extension for the spare.  I had placed the Borg order over the phone 800-300-2674 and they were very helpful.  Fast Tire doesn’t take appointments but when I got there, they started on it right away. They removed the tires, replaced the Ford sensors with the Borg extensions, spin balanced and reinstalled the tires.  All total it came to $120 for 6 tires and the spare.  I don’t know if that was a good price or not but they knew what they were doing and I was comfortable with the price.  They even put in the rubber stabilizers without telling them.
When I got back to camp I went to reinstall the wheel simulators but as others have discovered, the Borg extensions get in the way.  It’s only when putting on the rear wheel simulator that the Borg gets in the way.  Once install, the Borg is centered in the simulator hole.  So lucky for me, my daughter lives only a few miles away and was able to borrow her Dremel Tool and made a couple of notches in the rear wheel simulators (see pictures).
Next I busted out the TST-507-RV-6-C TPMS system that I bought at eTrailer.  At the time they were the cheapest but you may find them for less somewhere else.  I also purchased a 4-pack and a 2-pack of cap sensors for the toad and 2 spare tires.  I had to read and reread the instructions but I eventually got it right and paired the 12 cap sensors to the TST-507 😊
I still need to install the booster that came with the TST-507.  I’ll probably do what others have done and mount it above the rear window and tie into one of the LED reading lights for power.  The booster doesn’t draw much current and can be powered on all the time.
Now for the last part…  Like I said, the one downside to removing the Ford sensors is that the onboard computer will issue warnings that the pressure is low or that the sensor isn’t paired.  You can press OK each time you get the warning or you can use Forscan.  Forscan is a software program for reading and programming Ford truck onboard computer via the OBD2 port.  It can be a bit intimidating but if you’re careful and don’t change too many things you can make these warnings go away and never have to think about it again.  If you doubt your ability to do this, STOP RIGHT NOW.  Go and find someone who has the knowledge and is willing to do this for you.
Forscan has a few requirements if you want to do this.  First you need a Windows laptop.  There are versions of Forscan for iPad and Android tablets but only the Windows version allows you to make programming changes to the truck.  You can download Forscan for Windows here.  Next you need a OBD2 to USB adapter.  Forscan’s website has a list of adapters that are known to work.  I bought a Vgate vLinker FS OBD2 USB Adapter for FORScan for $34.99.  Next you need an extended license for Forscan.  This is required for doing more advanced things, but fortunately Forscan offers a 2-month free trial license that you obtain here.  You will need internet access when installing the license.  Last, if you purchased the same OBD2 to USB adapter that I did, then you need a Windows driver for it.  The driver download location is in the instructions that came with the adapter, but make sure you install it first.
Ok, if you got this far and have the driver and Forscan installed on your Windows laptop.  And you’ve got the adapter plugged into the OBD2 port under the dash and into your laptop.  And you’ve managed to follow the Forscan instructions on installing your 2-month trial extended license.  And you are able to “connect” to the trucks onboard computer… congratulations, you’re almost there.  Now you just need to disable 2 things related to TPMS.
- Turn truck key to on (engine doesn’t need to be running)
- Forscan should be running and you have a “connection” to the trucks onboard computer
- Click on the thing that looks like a chip (configuration & programming)
- Click on IPC Module
- Click on Run button on bottom left
- Find “TPMS Menu (additional change required in BCM)” select it and click “Edit selected”
- Select “Disabled” then click the check mark
- Click “Write” you’ll get a prompt to turn the ignition off and on. Do that and click OK
- Find “TPMS By Location Feature” select it and click “Edit selected”
You’re done… Turn the key off, disconnect the OBD2 adapter and close Forscan.  The Ford TPMS menu, display and warnings are now gone 😁
- John
Re: Replaced Ford TPMS with TST-507 & Borg valve extensions
It is important to note that aftermarket TPMS, particularly when mounted remotely on extenders, do NOT reflect tire temperature in any useful way. Mostly they will remind you on which side of the rig the sun is shining.
This is a follow on to my 1st post.  Today I installed the TST-507 booster.  I read where others installed the booster next to the back window and that sounded like a good idea.
I had placed the display in the lower left corner of the windshield and was concerned that the refrigerator, being right behind the driver, might interfere with the booster signal, so I placed the booster on the passenger side of the rear window.  Now I have a straight shot to the display.
The wiring was pretty straight forward.  I removed the passenger side speaker and drilled a 5/16” hole forward into the empty space under the passenger side cupboard floor and inline with the passenger side LED light.  I then drilled the same size hole in the corner behind the valences and up into the speaker area.  Dropped the passenger side LED light and fished the booster wire over to the light.  I did have to cut the fuse off of the booster wire before fishing the wire through and then splicing it back on when connecting it to the light.
Note: The LED light wires are black (+) and white (-) while the booster wires are red (+) and black (-).  You want to connect (+) to (+) and (-) to (-) or black to red and white to black.
The booster is held in place with Velcro that was supplied with the kit.  Works good too 😊
- John
Nice job, John! Do you have any photos of where you drilled the holes as I’m having a hard time visualizing it.
I mounted my monitor in the center of the dash using Command Strips.  The repeater is on the rear driver side and I got power from the small round light in that corner. I need to redo it but the signal strength seems to be fine.
Interesting! I always thought having the tpms system built in was a bit better just to avoid having another monitor gadget in the front. But I see the pros of it.
I recently found this tpms monitor which is not made for Ford, but I'm sure it could be retro fitted. I love how it would blends on the the dash. Biggest downside is that it's only for 4 wheels, but maybe getting two could do the trick??
Amazon.com: U912 Tire Pressure Monitor System TPMS Real Time Pressure...
1995 23.5 Rear Lounge
Hi Greg, here ya go… I didn’t want to unscrew and remove the speaker again, but I think you can get the idea.
- The first picture shows the light on the left where I tapped into the 12v power and the speaker on the right.
- The second picture shows how the speaker area is extended up into the cabinet.  With the speaker removed I had access from that area to drill into the false bottom of the cabinet with the light.
- The third picture shows the right-angle drill I used to drill from the speaker area to (and inline with) the light.
- The fourth picture is where I mounted the booster.  I couldn’t get a good picture of the hole I drilled but it’s straight up from the booster and into the speaker area.
BTW - Doing it this way I didn’t have to mess with pulling up the cabinet floor to get to the false bottom.  I hope this helps 😊
- John
wish I had gotten the tpms sooner, just lost all the air on an inner wheel in the back thanks to an extender coming loose and flying away!
If you were using the braided stainless steel tire valve extenders I am not surprised at that happening. Many years ago I too were using this type extender and had the same issues with them coming off or coming apart. I even had the crimped threaded end come off a new one out of the package! From then on I only use the solid stainless Borg style extenders on all coach wheels.
Since I also have the TST tire pressure monitors on end of these stems I did have to use tin snips to enlarge the holes in the rear
wheel covers for clearance of the monitors.
Mike
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
A Dremel tool works well on the wheel covers.
