Topic: 01 radio replacement, double din or 1.5 din? (Read 200 times) previous topic - next topic
Our 01 has a Kenwood head unit and 10 disc cd changer in it. I'm thinking it's about time to replace it with something we can load up with all our mp3's and get bluetooth, gps, and all that fancy new features. I haven't pulled the old unit out, or removed any of the plastic to see exactly how much space is available yet. I'm hoping some have already done that to know if a double din head unit can fit or not. I know it's bigger then a single din, as there is a little pocket above the radio, but I'm sure if it's a full double din or not.
I'm open to any recommendations of what folks have replaced their stock radios with.
2001 MB
Re: 01 radio replacement, double din or 1.5 din?
I have used Crutchfields for radios, installation kits and instructions for years. Recommended.
Crutchfield: Car Stereo and Audio, Speakers, Home Theater, Pro Audio, TVs
2001 Econoline
https://www.crutchfield.com/car/outfitmycar/mycar.aspx
This doesn’t answer your question about fitting a double DIN, but I went back-and-forth on this very question, as Crutchfield showed some double DINs available for my ‘03. So maybe at least it will help someone else if they’re searching this topic like I was a few weeks ago.
Ultimately, we just decided to save some $$ this time around since we have a separate Garmin nav that we bought just for the RV, we just need BT and USB input. Hate to remove a perfectly-good stereo, and it goes with the “retro” theme, but we need to be able to stream music.
Incidentally, the original Sony has RCA inputs on the back, and I investigated accessing those (but would still need to wire something to charge the passenger’s phone), but the $15 EBAY part to make those inputs work was a gamble. (You apparently have to trick the Sony into thinking a CD changer is sending in that signal). Hope that made sense.
Here’s what I got: Cost me $109.00, single DIN, JVC KD-T710BT, on Crutchfield.
Since LD deleted (or tossed) the Ford wiring harness, I just got the included Metra harness Crutchfield bundles in (and added a crimping tool and some connectors). Crutchfield was kind enough to give me a chart comparing my particular original Sony wire colors with the JVC’s (I had to ask the rep for that specifically), and after it arrives on Tuesday, I’ll use that and WxToads write-up to do the job — following his method.
I’ve already had the Sony out to confirm the absence of the Ford harness, mine wasn’t glued in as others have found. I had it out of the dash in less than a minute by popping the entire trim out that surrounds the stereo.
When/if I get a rear-facing camera, I’ll either have a separate screen mounted in place of or near the rear view mirror, or upgrade at that point with a double DIN to integrate the camera. If we were full-timing in this thing, obviously double DIN and integrated rear camera would’ve been the ticket for us.
Jason
2003 Rear Bath
"Razor Crest"
I just ordered a double DIN receiver (radio, Apple CarPlay, etc.) from Crutchfield on Thursday & it should be here tomorrow (2 day free shipping to CA).This is for my 2003. You can order a single DIN or double, they can walk you through all of that. Excellent online shopping experience. Radio package comes with full instructions, technical support, 60 day return & for the Boss product line & a 3 year warranty. They also have a harness so you don't have to try to match all of the various wires. I'll post once I've installed mine in a couple of weeks or so.
Formerly 1997 TK
Hi Henness:  A friend replaced his original radio with a double DIN radio. He had a 2001 MB. If I remember he had it done and it was a pain to get it to fit correctly, but eventually it did. A 1 1/2 DIN might be much easier.  It had a foldout, and retracting screen with a potential for a rear view camera. I don't think he ever put a camera in.  RonB
In the process of spending way too much to upgrade the radio in my TK with a  Kenwood DNR1007XR
Wanted something to simplify the dash and have
     Dedicated GPS
      Large screen
      SirusXM
      Backup Camera integration
The Kenwood seems to be the only option.
Here’s what I expect it to look like (not my install)
Dave
2017 TK
Go to Crutchfield's web site and call their help line. I have used them in the past . Make sure to get direct fit wiring connector harnesses. Also look up reviews on Kenwood. Some models no longer have gps updates from Garmin.
Dont get the HD.....the radio portion has a hard time finding the HD station on the highway. And when it does find a station and music starts it can make you jump out of your seat. Hard to see screen and touch screen is complicated.
I would rarther have a stand alone gps. Or just use my phone.
2017 Casita Spirit Deluxe
2016 Twin King 24ft
2017 Casita Independence Dlx
2004 Midbath 26.5
