Topic: water exits fill spout when hooked up to city water (Read 181 times) previous topic - next topic
Howdy everyone
On last outing while hooked up to city water,  I saw   water coming out of the fill holding  tank where water is put in to fill the tank
Never happened before, whats up and how do I fix situation?
Thanks,  Bob Wilson
2007 31 IB
Re: water exits fill spout when hooked up to city water
Hi Bob;  Water was back flowing through the pump's check valve, filling up the tank and coming out of the vent (small hole with screen).   Could have been something in the check valve that got through the strainer, a hard water deposit on the valve rubber flapper, or too much pressure from the water hose inlet. I think LD gives everybody a 40 psi regulator pressure reducer.  I never use water directly from a hose, I'm sure my regulator is in a storage compartment (somewhere). I don't need it to fill the tank.  RonB
When not connected to shore-water, the pump's check valve would allow leak-back if malfunctioning, causing the pump to keep running. My guess is you had the pump switched off, so did not notice this, so see what happens with the pump on. If it does not keep running, then there may be a pressure-relief valve in the pump to prevent over-pressure, and your shore-water pressure was too high.
Hi LD family, 👋
Same thing happened to me on my latest camping outing. Given that my LD is 18 years old and have had no troubles up to now I think the check valve has gone bad. Does anyone (Larry) know where this check valve is located and how to repair/replace?
Thanks for all LD knowledge 🚐😎
Lazy Bones 2 - Cynthia
2 Lazy Bones - Home
Any valves are part of the water pump head. There is also a check valve at the shore-water hookup, but that is to prevent water from flowing out that inlet when the water pump is on.
