Topic: Knock Sensor Location (Read 183 times) previous topic - next topic
Hey All.  We have a 1997 Ford E350 V10 motorhome and code P0326 is coming up for knock sensor.  Anybody have information on where to find and/or how to change?
Re: Knock Sensor Location
The knock sensor is located on the top of the block, under the intake manifold. It should be visible and accessible from the front of the engine when the air cleaner and the flow sensor ducting are removed,
Rats often build nests in this area and chew through the knock sensor's wire.
Thanks Larry
