Topic: Emergency brake fluid level (Read 330 times) previous topic - next topic
For those of you that have the emergency brake from hell it might be time to check fluid level. 2006 and a few other years.
Mine was low and I have already blown one up so I was motivated to check. If you skip it and lose you are looking at $1600 and maybe a tow bill.
It takes ATF H which isn’t very common.
Took 2-3 ounces to fill to the top. Last checked 4 years ago.
Harry 2006RB
Re: Emergency brake fluid level
The transmission-mounted parking brake was eliminated with 2008 Ford  E450s.
Our 2003’s parking brake lossened up at around 100,000 miles, I bought a rebuid kit for it but it isn’t something most home mechanics can deal with unless they have a hydraulic press and the collars needed to pull and install the bearings, plus a dial indicator to measure the needed free play clearance .
E450 parking brake rebuild | Flickr
I mentioned this link yesterday, it shows where the parking brake’s hidden oil fill pug is located and other detailsl including photos that can be printed and shown to your mechanic when he/she doesn’t believe there is an oil reservoir that needs to be checked.
The parking brake reservoir needs to be topped off with the same fluid used in the transmission.
Parking brake oil fill | Flickr
If it's low on oil, does it cause problems, even it you don't use it?
2005 Jayco 24SS
The parking brake has an intermediate shaft between the transmission and the brake drum on the rear of the brake unit. The shaft spins at driveshaft speed. If the brake unit fails, you are dead in the water until the unit is rebuilt or replaced.
Oil is cheap, repairs are expensive.
Yes. It has a driveshaft running through it with bearings that require oil. No oil you will hear a big bang and need a tow truck. Not using the transmission mounted emergency brake doesn’t help you at all.
Your wallet will need a transfusion.
Harry 2006RB
Larry,
Would this service using the emergency brake hidden oil fill plug apply to the 1997 MB LD, like mine?  Yikes, what else do I not know to look for?
Kristin
1997 MB
1996-2007 E450s have this type of parking brake.
Yes, and thanks to Larry's post about this in our introduction thread, our new-to-us 2003 RB is going to the mechanic to be checked for this (as well as the already-planned visit to check all other fluids/hoses/belt etc) prior to us picking it up for our "maiden" voyage back to FL next month. The current owner was more than happy to specifically ask his mechanic to check this for us. NEITHER one of us knew about this potential issue, and I'd bet if he didn't specifically ask his mechanic, then it wouldn't have been checked.
Jason
2003 Rear Bath
"Razor Crest"
