Topic: TV removal?  (Read 124 times) previous topic - next topic
TV removal?
Hi! I have a 2000 26.5’ RK with above cab entertainment center. In the small storage cubby above the TV I recently discovered that several items fell into a hole that drops behind the TV. I cannot figure out how to remove the TV to access these items. Several people I talked with said to locate screws under the carpet (that hold the bracket) but I do not see anything. Please help!
Re: TV removal?
Hi Mag;  Your 2000 came with a large power hungry tube TV, and what your picture shows is a flat screen LCD TV. So it has been upgraded, and should have a large space behind it.  I would try pulling the TV out toward you. It might be hinged at the top or side to act as a door for access behind it. Judging by the grille screen above it, the opening behind the grille that your 'disappeared objects' fell into, is probably ventilation for the TV and satellite receiver and/or DVD player behind it..    RonB
