Swivel chair pedestal base... October 08, 2021, 09:41:06 pm One of the swivel chairs in our 2004 FL developed a broken weld between the tension adjustment base and the steel post that fits into the pivoting leg/pedestal unit. The result was a very wobbly chair - not in danger of separating from the base, but annoyingly unsteady. I had tried various kludges to steady the post attachment, but all failed in short order. Luckily, I found an exact replacement base unit on Amazon, and it is a perfect fit:Amazon.com: Replacement Swivel & Tilt for Caster Chairs : Home & KitchenSteve As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Swivel chair pedestal base... Reply #1 – October 10, 2021, 06:43:14 pm Steve, is that the driver's chair? Karen~Liam 98 ~ MB NinA
Re: Swivel chair pedestal base... Reply #2 – October 10, 2021, 08:56:18 pm Quote from: Karen & Liam - October 10, 2021, 06:43:14 pmSteve, is that the driver's chair?It’s for one of the lounge’s barrel chairs.Good find, our chairs are getting loose.Larry
Re: Swivel chair pedestal base... Reply #3 – October 11, 2021, 12:20:17 pm We want a adaptable swivel that will also raise for our driver seat in our 98~MB. Our itaska had two for both driver and passenger chairs. I should have pulled one of them for our LD, thought I might find them out there but I have not found one that swivels and will raise a few inches. Karen~Liam 98 ~ MB NinA
Re: Swivel chair pedestal base... Reply #4 – October 11, 2021, 02:31:40 pm Wow, this is good timing. I just sat in one of my barrel chairs and noticed that the chair was wobbling all over the place. Flipped upside down and noted that the base appeared to be broken. Was going to take apart and see if I could weld it or otherwise replace it. Nope, just ordered the new base.
