Topic: Out Damn Spot Out (Read 243 times) previous topic - next topic
Out Damn Spot Out
I am fortunate to store my RB at home. While this is superior to RV storage yards, it presents one issue-Spinklers and the very hard water they spray on the rear of the rig.
Generally, I run out and use a microfiber towel to dry up the offending water. However, until recently, I was unable to remove the water before it dried and left Water Spots everywhere it touched.
I tried almost everything to remove them. Vinegar, detail spray, car polish, water...nothing worked. Until I found a YouTube video showing the wonders of “The Chemical Guys” water spot remover.
Following the easy steps, I accomplished what was until today a perplexing problem.
Here’s the Spot Remover as sold on Amazon...thank goodness for that.
Chemical Guys SPI10816 Heavy Duty... Amazon.com: Chemical Guys SPI10816 Heavy Duty Water Spot Remover (16 oz) :...
By first using a detailing spray, I cleaned small sections of the rig. Then using a clean microfiber towel, I applied the spot removing gel in straight lines (no circular motions) and with little effort I simply wiped the spots away. After that, I used the detailer to neutralize the gel residue and after I finished an area I waxed the area. Overall, the whole process is very easy to accomplish.
I am very pleased with the results. The spots have vanished completely. Here are some pics of the untouched spots compared to the completed areas.
Hope this helps those in the group who are also frustrated with water spots on their cars or Lazy Daze.
Re: Out Damn Spot Out
Thanks Joan,
The 14 page data report is very informative. The Water Spot Remover bottle label does list the precautions and safety protocol and the active ingredients of the product. Caution should be taken when using the product as outlined on the package.
The product is not a spray or liquid. It is a thick gel that is applied to an applicator and (ok so it is a liquid of sorts) then patted onto the surface of the affected area and then rubbed onto the surface.
Gloves and eye protection would be advisable, however as I used the product, I never came into contact with the gel or the damp surface of the applicator. This being the case, the YouTube presenters did not wear gloves or protective eye wear. Perhaps they were simply downplaying any contact hazards that may exist.
All this being said, I am very pleased with the results and despite my lack of protective gear I felt safe using the product. Others may decide to avoid this water spot remover or take additional caution while using it.
Thanks again for your very informative post.
Kent, I'm glad you are happy with the results. BUT, and maybe it is just me and my old eyes; your photos don't seem to show the same area or any improvement. I am not doubting your report but the visual evidence is not convincing to me.
Steve K.
Steve K
2003 Mid-bath
Hi Steve,
In my photos, I attempted to show the clarity of the finished work by contrasting the upper unresolved spot damage with the spot free section just below.
Water spots are difficult photographic subject and lighting is everything. As it is, the work is complete and the spots have all been removed.
Here are other pics that can, hopefully, highlight the spotting more clearly and the cleaned up panels.
I hesitated linking the Chemical Guys video, but here it is to better clarify the results. https://youtu.be/xBLGe--6cQA
Thanks Kent! It helps to know what I'm looking at. In the first photos I thought we were comparing the 2 photos to each other instead of the top and bottom sections.
Very nice results too.
Steve K
Steve K
2003 Mid-bath
