Topic: Fuel to generator on 2000LD (Read 380 times) previous topic - next topic
Generator quit ...just stopped running after 25 seconds......and I suspect fuel pump HOWEVER...NO FUEL runs out of hose from gasoline tank  ..after disconnecting fuel pump ..even when I lower hose to ground. I thought fuel would flow thru hose from gas tank. It flows on my 1985 LD,  when I lower hose to lower level. Gas tank is full.  I have bought new pump, but have not installed yet. WHY DONT FUEL FLOW BY GRAVITY? I  am confused.  HELP PLEASE...THANKS.
Hank
1986 22' Chevy G30 Multi-Plan
2000 Ford v10 23.5 Front Lounge
Re: Fuel to generator on 2000LD
If you can't suck fuel through the line from the generator to the tank, suspect a leak in the fuel hose letting air into the line.  I've seen deteriorated cracked hoses, as well as hoses damaged. by rodents.
You can try pushing / blowing air back through the line to see if it is otherwise clear.  If you listen carefully, you should hear air bubbles in the tank.
I have used a plunger like this one to push air in/out and troubleshoot.
Amazon.com: FloTool 10111/6 Mixmizer Injector : Automotive
Two possible causes .
Leaky, rotted fuel line, up at the tank and/or a siphon needs to be established. Do this at your own risk.
Mostly likely the rubber fuel line, up on top of the tank is rotted and leaks air. It’d quite common on rigs of your vintage.
Thanks...rubber hose NOT rotted near Genny.  I will  have a look near tank IF possible.  Thanks..I love my Vintage 2000 LD 23ft rear bath with V10!
Hank
Thanks..I bought the flo tube from AMZ.
CHEERS.
Hank
0is there a fuel filter from the gas tank to the fuel pump?
Hank
 I don't know about the 80's vintage generators, but the 2000's versions have a fuel filter immediately upstream of the fuel pump.  Trace the fuel line coming into the generator and you should see it if there is one.
Also check the oil level.
If it is low, it will do what you have experienced.
Jota
96 23.5 FL
I was looking 4 a filter from pump input back to gas tank.  I see the one between pump output and genny.  Thanks.
Hank
No. It is a bare tube that dips into the tank to the 1/4 level, at least on my 2006 Ford.
OK....the latest......I blew bubbles first.....then gas came out via gravity....SO....I put   OLD fuel pump back on......NO START....SO...I put on new fuel pump and filter.....still no start...it cranks great but no sta r t...have OLD air filter off now....still no start...OIL LEVEL 3/4...TANK 3/4......HAVE SPARK AS I GOT  a nice shock....NEXT. ...am thinking of spraying something into CARBY thru air inlet...I am   NEAR end of ideas and am 80 yrs old....all ideas will be appreciated...thanks....Hank
Hank
What else can it be??  Ran great...did not use in a month...ran 20 seconds....due to LOST PRIME maybe due to ALTITUDE CHICAGO TO VEGAS...MY CURRENT LOC A TION....WAITING FOR SENIORS POKER TOURNEYS.
Hank
No. It is a bare tube that dips into the tank to the 1/4 level, at least on my 2006 Ford. ?
Hank
Hank
RICH.....GAS IS COMMING FROM THE TANK.
Hank
2 things you can do if you're trying to figure out what's going on with your fuel system.
(1) Disconnect the fuel line from the carburetor and direct it into a safe container (glass jar or gas can or something).  Prime the generator.   This _should_ cause the fuel pump to pump fuel from the tank and into the new container.  Lack of fuel means you are not getting fuel from the tank to the genset.
(2) Disconnect the fuel line at the filter, and use a short piece of fuel hose to draw fuel directly from a fuel container.  If everything runs, the pump and the generator work, and the fuel delivery problem is upstream (between the filter and the coach fuel tank).
This video explains (1).  You might not have the same generator, but the principle applies.
https://youtu.be/U72Zmk0BF-o?t=224
Put your hand in front of the carburetor without the air filter to manually choke it. See if that will get it to run. Squirting propane or ether into the intake can tell you something. If it fires then fuel is not coming out of the carb. A replacement carb can be found on Ebay for $30-40. With that you have replaced the entire fuel system.
Let us know if you can get it running by manually choking, propane or starter fluid.
Harry 2006RB
I am going to check 12 volts to fuel pump TOMMORROW  as I have fuel from tank to pump but no fuel out of pump.
Hank
Problem solved;  AIR LEAK ON HOSE BEFORE FUEL PUMP INPUT.  Now just have go to ONAN  and buy a 1492333 fuel filter as the CRAP  one I b ought on AMAZON  is CRAP. $13 WASTED.
OH WELL ,  I  sav e d a ton of $$$$ doing it myself with FORUM  help; RICH  and others...
THANKS TO ALL.
I can now get ready for the WSOP Seniors Poker Tourney!
Hank
