Topic: Roof sealant (Read 366 times) previous topic - next topic
Roof sealant
Group
On the roof today removing old sealant. The old sealant is a brownish color with dicor over the screws.
What is the under coat?
It looks like a polyurethane of some kind.
1992 Mid Bath
Re: Roof sealant
This what it looks like
1992 Mid Bath
Re: Roof sealant
It's well age sealant of some sort, not sure when LD started using polyurethane as their primary sealant.
Cut it away and start over, a vibratory tool with a sharp blade easily cuts through it.
Re: Roof sealant
Thanks what I did. Should be finished Wednesday.
1992 Mid Bath
Re: Roof sealant
So.....did you go with the Locktite PL Poly or the Eternabond tape?
2016 Mid Bath
Re: Roof sealant
Pl loctiite. It has been a job. Now thinking of coating entire roof with a roof coating to maybe deflect some heat off the aluminum
1992 Mid Bath
Re: Roof sealant
Your roof should already be white, which is a great reflector of heat.
Unless you do a really excellent prep, any coating will be prone to peeling and cause a maintenance nightmare. Think long and hard before coating your roof.
Linda
Linda B
Green 2021 RB
2022 Ford Maverick toad
