Topic: Dash Cam (Read 368 times) previous topic - next topic
Dash Cam
We’ve begun a search for a dash cam, which we have no experience.  I’d like help selecting one.  I’d be grateful for any guidance.
Re: Dash Cam
We bought a Garmin 7" RV Navigator 785 with a built-in dash cam. It has a good wide angle image and works well at night. The GPS has up to date traffic monitoring and settings for your motorhome size and road restrictions (like low bridges).
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
Re: Dash Cam
The main things I look for in a dashcam are:
* The highest possible resolution (e.g., 3,840 x 2,160), because I may want to read license plate numbers in that video.
* A built-in "supercapacitor" to maintain clock and other settings, rather than just a rechargeable battery--the windshield can be a very hot location, and in my experience batteries don't do well there.
* GPS capability--this records time, date, speed, and exact location as part of the video, all of which are potentially very useful if the video is ever needed as evidence.
* A small LCD screen and button controls, as well as Wi-Fi.
At first I favored small, cylindrical dashcams because they're inconspicuous. But after owning a couple different brands of that type, I found that the Wi-Fi connections were not always reliable. When that's the only way to configure the dashcam (there are a lot of settings), it can be frustrating. And of course if the accompanying smartphone app "breaks" when you update your phone's OS, you're out of luck. Granted, it's usually easier to configure a dashcam using a smartphone app, as long as that works... but a camera that has its own screen and buttons gives you a second way to do it, if the phone-based approach fails.
I've owned a variety of dashcams over the years, but the best ones I've found so far are two Rexing models. Their V1-4K is reasonably priced at $120 including a small separate GPS module. Their $200 V5 model has the GPS built in, which is convenient. And the V5's lens is mounted on a ball joint, which gives you a bit more flexibility in aiming--for example, if you mount the camera on the right side of the windshield, you can angle the lens left a bit to center its field of view on the road. (The V1-4K's lens swivels up and down, but not side to side.)
One more note: many people are adding rear cameras, and judging by some of the videos I've seen of cars being rear-ended, that seems like a good idea. The V1-4K doesn't have this option, but the $160 V1P-4K model does--it comes with a 1,080 x 780 pixel rear camera that can be wired to the main camera in front. The Rexing V5 doesn't come with a rear camera, but their $60 wired accessory camera records 2,160p video. I plan to add some kind of rear camera to my car soon.
Re: Dash Cam
Thanks Andy for this information.  The Amazon listing does show a rear camera option for $60.   This looks like a very capable unit and I will probably order one.
Re: Dash Cam
We purchased a Garmin 890 RV 18 months ago (link below).  We chose that model for the RV features, many of which are helpful.  We also chose the 890 because it allowed us to connect one of Garmin’s standalone 12volt dash cams to the GPS mount.  We can thus power the system from one cord and control the dash cam from the GPS unit.  Of equal importance, we were thus able to move the dash cam to our towed and other vehicle when at home.  While I’ve not done so, a rear mounted camera can be connected to the 890 wirelessly.
Warren
Garmin RV 890 - TechnoRV
Warren
2019 MB “Dream Catcher”
Jeep Wrangler JL
Re: Dash Cam
The Garmin add-on dashcams are certainly convenient. They have one drawback: modest resolution. Here are the resolution specs for Garmin's four add-on dashcams, as well as the two Rexing models I mentioned:
Garmin 47, Mini 2: 1080p--1,920 x 1,080 = 2.1 megapixels
Garmin 57, 67W: 1440p--2,560 x 1,440 = 3.7 megapixels
Rexing V1-4K, V5: 2160p--3,840 x 2,160 = 8.3 megapixels
If you want to be able to read crucial details such as license plate numbers, you want the highest resolution you can get. Even Garmin's most expensive 57 and 67W models record less than half the detail of the Rexing V1-4K cameras, while costing twice as much.
Rexing isn't the only company making 4K resolution dashcams; they're just the ones I have experience with. There are plenty of other choices. And of course, almost any dashcam is better than none at all. But unless you're on a super-tight budget, I recommend limiting your search to cameras with no less than 4K (2160p) resolution.
Re: Dash Cam
"Rexing isn't the only company making 4K resolution dashcams; they're just the ones I have experience with. There are plenty of other choices. And of course, almost any dashcam is better than none at all. But unless you're on a super-tight budget, I recommend limiting your search to cameras with no less than 4K (2160p) resolution."
Andy,
I've had two different dash cams since a couple of near misses caused by careless drivers a few years ago. I have an inexpensive Garmin now, but don't care too much for it. Could you talk a little more about set up and ease of use of the Rexing please? Both of the ones I've had were so hard to navigate with the small buttons and extensive menus (almost too many features). I'm accustomed to fussing with electronics set up, but sometimes I wasn't sure I had the darn things configured properly, or that they'd stay that way. It seems that they should be easy to set up for basic functions. Is that true with the Rexing?  Thanks for any more info!
Bill
Bill
2003 -- 23' FL
Re: Dash Cam
These dashcams do have a lot of options, but most can be left at their default settings, so setup is not that difficult. And once it's done, it's done. I haven't needed to change anything about my V1 or V5 since I first set them up.
But judge for yourself. Here are the owner's manuals for the Rexing V1 series and for their V5 model.
Re: Dash Cam
These dashcams do have a lot of options, but most can be left at their default settings, so setup is not that difficult. And once it's done, it's done. I haven't needed to change anything about my Rexing V1 or V5 since I first set them up. They start recording as soon as I turn on the ignition, and turn off when I shut down the car. I don't have to touch them, unless I want to pull the microSD card to review something. ("Oh, look--a monster trike!")
Re: Dash Cam
These dashcams do have a lot of options, but most can be left at their default settings, so setup is not that difficult. And once it's done, it's done. I haven't needed to change anything about my Rexing V1 or V5 since I first set them up. They start recording as soon as I turn on the ignition, and turn off when I shut down the car. I don't have to touch them, unless I want to pull the microSD card to review something. Oh, look--a monster trike!
Thank you Andy for all of this! It is reassuring that you haven't had to 'tinker' with them once set up. I'll follow the links to learn more. One of the two I had in the past did have GPS. I think it was a worthwhile feature, and would definitely spend the extra $$ for it.
Bill
Bill
2003 -- 23' FL
Re: Dash Cam
A front and rear recording camera looks to be a good idea. Since the cameras are higher def than most aftermarket rear-view cameras, I wonder if they could be used with a larger dash monitor as a front or rear view camera, eliminating the camera redundancy.
Re: Dash Cam
"Since the cameras are higher def than most aftermarket rear-view cameras..."
Tell me about it. One of my biggest gripes about rear-view cameras is that all the ones I've seen have very low resolution by today's standards. 640 x 480 pixels or thereabouts is pretty common--e.g., the Voyager fear-view camera that came with my 2019 Airstream. That's a third of a megapixel! Pathetic.
"I wonder if they could be used with a larger dash monitor..."
Judging by the last few vehicles I've owned (two Ford pickups and two Subaru SUVs), the problem is that there just isn't anyplace to put a large dash monitor. Most modern vehicles already have one built in, but what's missing is a way to get a video picture onto that screen.
Heck, I'd be happy if my car would let me see the image from its built-in backup camera while I'm driving. That camera looks plenty sharp on the screen-- a damn sight sharper than what I get from the Airstream's Voyager camera and monitor. But no, it only shows up when I'm in reverse gear. :: sigh ::
Re: Dash Cam
I was thinking about our Lazy Daze, it already has a rear-view 7” monitor on the console but it’s low-def.
Our 2020 Jeep's rear camera is high-def, it’s monitor is large and it’s easy to see the little details, I would love to have one like it for the rear of the LD
