Voltage still present after fuse is pulled. August 16, 2021, 07:05:36 pm We have a 1998 30 IB. When changing the light fixtures near the bed, I measured the voltage at 13.3 volts. I then pulled all three 20 amp lighting fuses and checked the voltage again. It measured 8.3 volts. Any ideas where the phantom voltage may be coming from?
Re: Voltage still present after fuse is pulled. Reply #1 – August 17, 2021, 06:46:00 am Do you have a solar panel? If you do, you need to pull the solar fuse too.Steve K 2 Likes
Re: Voltage still present after fuse is pulled. Reply #2 – August 17, 2021, 09:00:03 am Therman,Does you fuse board have built in LED blown fuse indicators? The appliance is the ground B- for the LED blown fuse indicators. 2 Likes
Re: Voltage still present after fuse is pulled. Reply #3 – August 17, 2021, 10:19:49 am Rodney is correct. If the LEDs are there, this is not a problem.Steve 1 Likes
