Screen Door Latch & Handle Replacement August 03, 2021, 09:15:15 am Anyone ever have to replace the screen door latch and handle assembly?Is this a "Mother Ship Order?"Cheers!Tony R. (aka codefour)
Re: Screen Door Latch & Handle Replacement Reply #1 – August 03, 2021, 09:40:25 am Seems like an easy Mothership order
Re: Screen Door Latch & Handle Replacement Reply #2 – August 03, 2021, 09:42:33 am Widely available. Amazon.com : rv screen door handleRich 1 Likes
Re: Screen Door Latch & Handle Replacement Reply #3 – August 03, 2021, 10:08:23 am Thanks Rich - Will be delivered tomorrow.What would we do without Amazon!Cheers!Tony R. (aka codefour) 1 Likes
Re: Screen Door Latch & Handle Replacement Reply #4 – August 03, 2021, 10:10:52 am Yup. As an aside there is a left and a right hand replacement parts. Double check to make sure you get the proper part. glen
Re: Screen Door Latch & Handle Replacement Reply #5 – August 03, 2021, 10:15:58 am On the subject of screen door latches, has anyone found a commercially available inside release that avoids the need to slide open the plastic panel? I’ve seen the homemade latch pulls but haven’t been able to locate a manufactured replacement latch or latch assist.W 1 Likes
Re: Screen Door Latch & Handle Replacement Reply #6 – August 03, 2021, 10:17:14 am Quote from: codefour - August 03, 2021, 10:08:23 amThanks Rich - Will be delivered tomorrow.What would we do without Amazon!It looks like you have it all under control, but you can find this part at almost any RV supply. Mine recently broke at Navajo Lake State Park, and my brother found one for me in Aztec, NM and replaced it.
Re: Screen Door Latch & Handle Replacement Reply #7 – August 03, 2021, 10:23:06 am Quote from: WhiteElk - August 03, 2021, 10:15:58 amOn the subject of screen door latches, has anyone found a commercially available inside release that avoids the need to slide open the plastic panel? Iâve seen the homemade latch pulls but havenât been able to locate a manufactured replacement latch or latch assist.WAmazon.com: Camco 43953 RV Screen Door Opener: Automotive 1 Likes As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Screen Door Latch & Handle Replacement Reply #8 – August 03, 2021, 01:13:26 pm Amazon.com : rv screen door slideThis type has a double sided disc with a spring mechanism. Their is a post on each side . Push on post from inside and by way of spring setup it moves the outside post down to engage handle. Once you let up on post the spring returns the outside post upward. The slider can be moved if needed to lock the door. The company patent is by Lippert Co.Lippert - Leading US Supplier of RV Components | Lippert .This one is for a.casita so check the dimensions of the Lazy Daze. Or call company and ask. See utube video of how to install and how it works.https://youtu.be/qYOeSYQmxYA
Re: Screen Door Latch & Handle Replacement Reply #9 – August 03, 2021, 06:51:10 pm Has anyone put this type of pull-down screen door latch like in Tony's post on a 90s LD? Does it fit? I've bought several styles of latches over the years only to return them because I couldn't get them to fit. 1 Likes
