Topic: Air Conditioner is a keeper also (Read 260 times) previous topic - next topic
The house air conditioner on our 2021 MB is great.
106 degrees outside and it kept us in the mid 70s.
Our 95TK couldn't pull that off.
 :D
Re: Air Conditioner is a keeper also
That's great. Could you share if known.  Is there an evolution of the insulation in ceiling and walls.  R Value, placement or insulation products change throughout the years?
Thank you,
Nadine
Thank you,
Nadine
I know my 95TK had fiberglass insulation and this new one has foam panels I believe.
I know my 2010 LD had 1.5" block foam insulation in all the walls, floor, & ceiling of the coach and they continue to do the same afterward to the present. (see photo)
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
LD went to a slightly thicker aluminum roof sheet and styrofoam block insulation in models produced in spring, 2008.
Re: insulation--see my post here. LD changed over from fiberglass to rigid foam insulation in early 2008.
Wonderful  and informative information everyone.  Thank you!
