LED Step Light June 28, 2021, 12:28:38 pm Ours has stopped working…anyone replaced this ? I think it may be the same as the nite liteThanks,Bill
Re: LED Step Light Reply #1 – June 28, 2021, 12:37:15 pm Yup very simple swap out. The white housing pops off with a gentle pry with a flat head screwdriver. If I recall correct there is a small tab. It uses a 198 bulb I believe but refer to your manual. I replaced all mine with LEDs from Amazon.
Re: LED Step Light Reply #2 – June 28, 2021, 12:43:22 pm Quote from: brewersarcade - June 28, 2021, 12:37:15 pmYup very simple swap out. The white housing pops off with a gentle pry with a flat head screwdriver. If I recall correct there is a small tab. It uses a 198 bulb I believe but refer to your manual. I replaced all mine with LEDs from Amazon.Ours (2013) are already LED….there’s a small slot underneath the housing but before I try to pry it off, I thought I’d see if others had the same issue
Re: LED Step Light Reply #3 – June 28, 2021, 06:00:15 pm "Ours has stopped working…anyone replaced this ?"Until I looked at the photo I presumed that you were talking about the light outside, under the steps.
Re: LED Step Light Reply #4 – June 28, 2021, 06:32:07 pm Quote from: Lazy Bones - June 28, 2021, 06:00:15 pm"Ours has stopped working…anyone replaced this ?"Until I looked at the photo I presumed that you were talking about the light outside, under the steps. Only the electric steps have the exterior light below the steps.Larry
Re: LED Step Light Reply #5 – June 28, 2021, 06:43:47 pm Quote from: Larry W - June 28, 2021, 06:32:07 pmOnly the electric steps have the exterior light below the steps.LarryThis is the foot light just inside the door that shines onto the step up into the coach (we have the electric step)
