Topic: 2001 MB (Outside Window HEHR Glazing Bead (Read 89 times) previous topic - next topic
 In need of window glazing bead seal outside HEHR window for a 2001 MB.    I’m referring to the outside window rubber molding that holds the window in place.  I believe glued from the inside.   I realize the need to cut a small drain trench at the bottom.   I want to replace window glazing bead seals on my 3 rear windows.   And eventually every window.
My best guess is the 1/8” window thickness size by links below.  Is this the correct material?
Hehr Glazing Bead Seal | All-Rite Custom Manufacturing | RV Parts | RV...
1/8" Glass Glazing Bead - RV Windows
Thanks,
 LarryD
2001 MB
