Dry lube for sticky lock June 17, 2021, 02:13:36 pm I had a sticky car door lock and found this stuff while I was in Lowe’s, although you could probably find it at any hardware store or Amazon. I sprayed a little in the keyhole and bam, no more sticky lock. I also had a padlock that sits outside exposed to the rain and had gotten hard to turn the key. Again, a quick spray in the keyhole and it felt like new again. You should never spray WD40 inside a lock because it will attract dirt and gum things up. But this stuff says that although it penetrates, it doesn’t attract dirt. I have no association with 3-IN-ONE and this is only my opinion. I’m just thinking this product may help others with a similar problem.3-IN-ONE Lock Lube- John
Re: Dry lube for sticky lock Reply #1 – June 17, 2021, 02:18:11 pm I've had success with Graphite based dry lubes for locks.
Re: Dry lube for sticky lock Reply #2 – June 17, 2021, 02:57:06 pm " I sprayed a little in the keyhole and bam, no more sticky lock."The main ingredient is Graphite, held in suspension by a liquid carrier that evaporates and leaves a slick surface behind. It's found under many brands in hardware and big box stores. 1 Likes
