Looking for replacement single pane glass alternative to NagcoGlass June 04, 2021, 05:55:21 pm Our driver side lounge fixed single pane window has developed a crack in it and is growing, now is a foot long. I called the mothership, they suggested NagcoGlass in Pamona. I called them and they said that their supplier does not have access to the necessary materials at this time if ever? The wait sofar has been over a month. Has anyone used someone else with this right thickness 3/8s and the right tint for that window approximately 32"X 24" ? The real issue is not the installer but the supplier? Thanks Karen~Liam 98 ~ MB NinA
Re: Looking for replacement single pane glass alternative to NagcoGlass Reply #1 – June 05, 2021, 01:01:45 pm Has no-one replaced any of the single pane glass in their older LDs? Karen~Liam 98 ~ MB NinA
Re: Looking for replacement single pane glass alternative to NagcoGlass Reply #2 – June 05, 2021, 01:29:06 pm If you haven't done so already, you might check with local-to-you auto glass companies; they may be able to find glass of a compatible thickness and tint and do the repair. I'm surprised that the thickness of the single pane glass is 3/8"?
Re: Looking for replacement single pane glass alternative to NagcoGlass Reply #3 – June 07, 2021, 04:29:17 am Hi Karen & Liam; I had my handy micometer and thought I'd measure the thickness of my '99 bathroom window. The dual thickness pane is not a thermal double pane assembly. I came up with .126". Just over an 1/8 th of an inch. That actually is pretty thick for an RV window. If you are searching for 3/8" thick glass, that would explain why no one stocks them. RonB. 2 Likes
Re: Looking for replacement single pane glass alternative to NagcoGlass Reply #4 – June 07, 2021, 01:17:42 pm Thanks RonB, I actually looked up the specs from an earlier post here on LDO which claimed the thickness to be 3/8, I have not measured it. Now I have your measurement for thickness .126". Joan I will check with glass companies around here since NagcoGlass was unable to help me at this time. With the thickness number from RonB which would be more standard then the 3/8 I thought it to be, I should be able to get it done sooner. Karen~Liam 98 ~ MB NinA
