Topic: Odd fitting (Read 183 times) previous topic - next topic
Odd fitting
Driver's side rear bumper corner area.
Mid-Bath.
Anyone?
Re: Odd fitting
That is where the outside remote temperature sensor lives. You should be able to find it inside when the cap is removed.  Not sure why they designed it like that.
Good to see you getting underneath and into the weeds!  👍
Re: Odd fitting
It lets in air to get the temperature, but keeps it mostly water tight.
Linda B
Green 2021 RB
2022 Ford Maverick toad
Re: Odd fitting
Unscrew the large PVC nut and there is a sending unit up inside the pipe. It resembles a tv remote. No buttons but a panel to slide open to insert new AA batteries.
One more annual maintenance project. 🤪
Re: Odd fitting
The previous owner of my LD had purchased a new temperature station for the motorhome but the new outdoor sensor was slightly larger than original. I temporarily relocated it into the unused sewer hose storage compartment.  One of these days I’ll crawl underneath and drill the PVC fitting out a little larger to accommodate the sensor. Since the photo was taken, I’ve installed gasket material around the little door to help resist water intrusion.
Re: Odd fitting
His a key location posing a a black tank something or other.
Previously: 2007 Mid Bath
