Under sink measument on a 27MB for water filter April 13, 2021, 03:38:38 pm Would someone measure the height of the undersink cabinet on their 27MB and report it for me?I am shopping for undersink water filter units.Thanks
Re: Under sink measument on a 27MB Reply #1 – April 13, 2021, 04:59:43 pm Ted, the actual cabinet is about 18 inches high but you only have about 12 inches to work with underneath the sinks. And of course, the drain pipes and P-trap is under there as well. You will lose some storage space for your pots and pans; that’s where we keep ours. 1 Likes
Re: Under sink measument on a 27MB Reply #2 – April 13, 2021, 07:49:33 pm Quote from: HiLola - April 13, 2021, 04:59:43 pmTed, the actual cabinet is about 18 inches high but you only have about 12 inches to work with underneath the sinks. And of course, the drain pipes and P-trap is under there as well. You will lose some storage space for your pots and pans; that’s where we keep ours.Thanks for info and pic.I'm looking at this "one/two punch" solution:WHOLE RV WATER FILTER UNDER SINK WATER FILTER
Re: Under sink measument on a 27MB Reply #3 – April 14, 2021, 11:17:26 am Hi, Ted.The setup in our MB, including the under sink component, is described here: Water filterWe used the components you linked to above. We're very pleased with the system.BTW, the entire thread I linked to is excellent. Jim 1 Likes
Re: Under sink measument on a 27MB for water filter Reply #4 – April 14, 2021, 01:13:04 pm Quote from: CBSShermans - April 14, 2021, 11:17:26 amHi, Ted.The setup in our MB, including the under sink component, is described here: Water filterWe used the components you linked to above. We're very pleased with the system.BTW, the entire thread I linked to is excellent. JimWow.Thank you for this. I'm in contact with Dave right now. I will go with this faucet most likely however everything else is the same. Color Faucets - Premium Ceramic Disc Designer Faucet - Brushed Nickel Coke
Re: Under sink measument on a 27MB for water filter Reply #5 – April 14, 2021, 02:30:27 pm I use one of these under the kitchen counter, the cartages are replaceable and filter most of the bad stuff.Ultrapure Under Sink water filter SystemThe RV Water store has a wide selection of filters.Larry 1 Likes
Re: Under sink measument on a 27MB for water filter Reply #6 – June 03, 2021, 09:10:32 pm We went with the Everpure EV9275-60 QL2-OCS 2 System since it looked like it would fit best under the sink in our 98~MB. We added a dedicated faucet with a flexible neck for filling water bottles etc. The faucet fit right in the hole for the soap dispenser and the flexible neck moves out of the way if necessary. We still carry a few jugs like before but it is nice to fill water glasses and water bottles directly without pouring out of a jug. Karen~Liam 98 ~ MB NinA 3 Likes
Re: Under sink measument on a 27MB for water filter Reply #7 – June 04, 2021, 03:35:27 pm As it turns out we had previously installed this flexible neck faucet in an outside kitchen sink in our patio some years. When we need to fill things in the patio area, we could with out having to put the receptacle in the sink. Its great for filling watering cans etc... Although we will probably not be filling watering cans in our LD. Karen~Liam 98 ~ MB NinAInchant Single Lever Flexible Pull Out Kitchen Water Tap Sink Faucet... As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
