Topic: Rear brake replacement (Read 424 times) previous topic - next topic
Has anyone got a quote or replaced their rear brakes recently?  We may need to do it away from home.
     Karen~Liam
        98 ~ MB
           NinA
1998 ~ MB  WanderDaze
Re: Rear brake replacement
     Karen~Liam
        98 ~ MB
           NinA
Yes, we had it done at a Ford truck facility a couple of months ago. Unfortunately, we currently are 400 miles from home and the paperwork, but can provide the cost when we get back next Monday. — Jon
On a 1988 MB E350 in 2018, $1500.00  Rear Shoes, Wheel Cylinders, Hose, frame to axle, Brake Fluid change, At AAMCO Automotive Service center. turned drum maybe.
Rodney
1988 Mid Bath
I would suggest using Ford.dealer parts if you don't go to the dealer. The parts you buy from Ford come with a 3 yr warranty regardless of mileage. It won't cover worn brake pads but no one does except double price junk pads. If you have an older coach like my old 2004 with 60k miles and it had towed a Subaru up and down mountains. I would suggest new brake lines as soon as possible...info on the net says as they age they collapse and cause issues with calipers.....which is another issue....Ford has had trouble with seizing calipers and aftermarket units also. The previous owner had a full front brake job( pads, hubs/rotors calipers and a brake flush) at a brake place....a year and 2k miles from when I bought it. They seized again after I bought it...the shop refused to replace the job of course. I went with all new parts including brake lines front and rear. 400 hundred miles down the road...might have been there before but coming down out of Blue ridge mountains I heard noise  from the rear...back to the shop..new calipers but the rotors and pads were able to use again...caught it in time. I think that due to the weight and heating and cooling of 5he brake fluid....this is where the issues start....condensation develops in the fluid and starts to cause rusting in the pistons of the calipers....when pads are replaced the pistons are pushed back and now rub on the rusted area in the cylinders of the calipers.....Brake flushes every 2 years and once a year if towing would prevent this costly repair. There is one thing I do on all my vehicle is between brake flushes I use a large stringe(used only for brake fluid) and remove fluid from reservoir to keep it clean and free of as much moisture as possible.....brake fluid is cheap compared to calipers. Just don't used old open containers of brake fluid...it will have moisture in it from sitting....don't go cheap use new. I think it cost me 1800 on the fronts with lines, calipers, pads, hubs/rotors fluid flushed...a little preventive maintenance makes you a happy camper. In the long run...
2017 Casita Spirit Deluxe
2016 Twin King 24ft
2017 Casita Independence Dlx
2004 Midbath 26.5
We were on our way to Bend from the Oregon coast when we began to hear the rear brakes, by the time we got to bend there was some metal to metal noise.  Les Schwab was able to get us in where as Ford dealers do not work on RVs here and the places they suggested were weeks out and twice the price of Led Schwab.  In all it cost $940 for full replacement with new parts, the only way they do it.  We got our 98~MB in at 8am and it was done around noon.  Karen got in line, 48 people by in line 8:15 she was number 5.  Wow Saturdays in Bend, we guess a lot of people were change overs from snow to summer tires.  We did stop in the day before to order parts so they knew we were coming.
           Karen~Liam
              98 ~ MB
                 NinA
Finally got the paperwork from the rig. Our rear brakes job at the Ford truck facility (Torrance, CA) was $469.95 (P&L) for replacement of the pads, lubing the calipers slides, machining the rotors, and test drive.  Larry’s probably rolling his eyes, but a master mechanic I’m not. 😉. — Jon
K&L,
Looks like you did well in Oregon.  I experienced similar price differences between California and Oregon.
Rodney
1988 Mid Bath
Thanks Jon,
I did not not have much choice, I would have preferred to get our LD back home where I could have done the work for less.  They replaced everything and totally flushed the brake lines in the whole system, something that was on my list, now crossed off ✔.
    Karen~Liam
       98 ~ MB
          NinA
