Topic: Steel Roof Support (Read 257 times) previous topic - next topic
Steel Roof Support
Does anyone here know what the steel roof support looks like ? Does it go down to tie into the chassis? Does it span the roof? Is it only corner braces at the roof wall joint ?
20 + MH's since 1977 incl...
Past
FMC, 2x GMC's, Foretravel, 2x LD
Present
1996 LD RB under restoration, my project to keep me off the streets.
Re: Steel Roof Support
LDs have three square, steel tubing frame members, sometimes called roll bars. They are located at the front, where the bunk begins, one in the middle somewhere and one at the rear. They run up one side, over the top, and down the other side.
They do not mount to the chassis's frame, they are part of the coach.
At the corners, there are steel gussets that reinforce the steel frame, sometimes found inside the cabinets or closets.
You might browse through this pinned thread to see if you can spot the roof supports: Lazy Daze Construction Photos
Thanks Chris, I had gone over the photos but hadn’t spotted them till now. Are they the same, looks like 2x2. Across the roof ? I’m trying to figure out if it’s possible to fish a wire fore & aft in the roof of my '96.
Past
Present
Fishing wires through the roof is very difficult, if not impossible.
Besides the steel bars, the roof joists' '1-1/2" tall bays are filled with fiberglass.
Running wires fore and aft in a Rear Bath is better done through the upper cabinets and wardrobe, on the driver's side, it's a straight shot across the top. The passenger side is difficult to run through. with the entry door and shower in the way.
The bottom floors of the overhead cabinets are removable (after prying the staples up), exposing a Factory wiring run.
WIres can run through the cabinet's floor cavity and the cabinet's floors are also a source of 12-power, by tapping into the power from the under-cabinet lights. Once complete, screw the floor back into position.
Here is what the inside of a cabinet looks like with its floor removed.
Wires in overhead cabinet---1 | Wires to switches in bunk ar… | Flickr
The wires can also just run along the top or side of the cabinet's interior.
For applications where the roof is the only pathway, surface-mount wire molding works fine too.
Amazon.com : wire molding
