Topic: Exploring under the Mid-Bath Sofa (Read 189 times) previous topic - next topic
I wanted to investigate what’s under the rear passenger side sofa for an upcoming install of the quick disconnect for a Wave propane heater. While I had the sofa apart it was a good time to install the valve extenders for the spare tire since the tire was so accessible. Here are a few photos:
Re: Exploring under the Mid-Bath Sofa
It's interesting to see how LD has changed the seatbelt mounts since my 2003.  Older versions are mounted through the wall, leaving no easy way to change/replace/add belts.
I did the same thing with my spare tire (repurpose old valve extenders for easy pressure checks), and it's been useful.
Yeah, I was wondering what the large holes in the plywood sofa base were until realizing they were for the seatbelts to feed through.
