Topic: How to destroy a perfectly good Jeep Rubicon (Read 284 times) previous topic - next topic
Re: How to destroy a perfectly good Jeep Rubicon
Ouch!  That’s a costly mistake.
- John
From a favorite website of mine...
dog Zeke
I can tell in the first foot I drive if the Jeep is set up right or not. If there is any resistance at all. I stop.
Yes, I was wondering about that. In first gear and "4-LOW", the Jeep must have a tremendous drag. But maybe the owner had a powerful diesel pusher and just didn't notice.
“I can tell in the first foot I drive if the Jeep is set up right or not.”
I use the following procedure, excerpted from the Jeep JL Wrangler manual, after hitching the Jeep to the coach and placing the transfer case in neutral, but before pulling away. I think that the poor fellow that blew up his rubicon motor did not read or follow his instruction manual.
Put the Jeep into Drive, press the gas pedal and verify that the engine revs freely.
Then, repeat with the transmission reverse.
Finally, place the transmission in park before pulling away.
Warren
Warren
2019 MB “Dream Catcher”
Jeep Wrangler JL
Older Jeeps require leaving a key in the ignition to allow unlocking of the steering. A kill switch is a good idea in these models.
Many find the placing of the automatic transmission in Park strange when towing, that's how Jeeps are designed. The transfer case has a true neutral that disconnects the engine from the rest of the drivetrain.
Hard to imagine how the motorhome pulled the Wrangler without hearing or feeling it. A Rubicon's 1st gear, with a manual transmission and the transfer case in low-range (4:1 ratio), is an extremely low gear.
As Don said, the feeling that something isn't right is immediately apparent, when starting to move.
"Many find the placing of the automatic transmission in Park strange when towing, that's how Jeeps are designed. The transfer case has a true neutral that disconnects the engine from the rest of the drivetrain."
Well, I sure did, which is why I asked you!  ;)
May I quote mother "All lessons  cost money thank god for the cheap ones"
glen
