Topic: Water Heater Thermometer (Read 123 times) previous topic - next topic
Soon I think I will have replaced every little thing on our rig. I noticed the aquarium thermometer that shows the water temp was no longer working. Another $5.
You might want one. I think Andy came up with the idea. Of course, it would kinda useless unless you also swap out the thermostat on the water heater for an adjustable one. Those cost more than $5, but worth it to me, as the water temp can be set lower than the standard of 150? We like 120 degrees.
Aquarium Thermometer
Adjustable Electronic Thermostat
How to install
Install the temp read out - I drilled a 3/8 inch hole near the back of the clothes cabinet in our MB to insert the temp probe through to the water heater. Remove the second drawer and you will see what to do. Cut out a small chunk of the styrofoam covering the tank, put the probe in, and replace the styrofoam. Mount the read-out display over the hole.
Re: Water Heater Thermometer
"Of course, it would kinda useless unless you also swap out the thermostat on the water heater for an adjustable one."
That particular thermometer displays the temperature, which is fine. (I used the same model on my fridge to monitor the freezer's temperature.) But what really works well for showering is an aquarium thermometer with an alarm. Set it to the temperature you find comfortable, activate the alarm, and turn on the water heater. When the thermometer beeps, turn off the water heater. For more details, see this page on my website.
"the water temp can be set lower than the standard of 150? We like 120 degrees."
I tried an adjustable thermostat a few years back, but I must be a sissy, because I found that even at its lowest setting it was still too hot for me. With an alarm-equipped thermometer as described above, I get exactly the temperature I want every time.
But for couples, there's a potential drawback to my method: because the thermometer isn't controlling the water heater it doesn't maintain my ideal temperature. If a second person wanted to shower after me, they'd have to go through the wait-for-the-beep procedure again to get back up to the desired temperature--it wouldn't be automatic. Obviously an adjustable thermostat is the ideal solution... if you can find one that can be set low enough.
Since we're talking about thermostats, I want to mention a unit that I recently bought that does an outstanding job at a very low price. Two products, actually. One's a thermostat and one's a thermometer.
First, the thermostat. Fair warning: to make this work with your water heater, you'd have to do some wiring. I haven't tried, although I might someday when I have nothing better to do. Same goes for your fridge, although that is the application I bought it for. But with my Vitrifrigo fridge, it was easy to disconnect the two wires from its mechanical thermostat and substitute two wires from this electronic one. Dometics? I dunno.
With that said, the Inkbird (yeah, I know, goofy name) is a general-purpose electronic thermostat that can control heating or cooling devices, or both, and it's both cheap ($15) and very accurate. It's a compact little box that's easy to wire in and program. It has two relays--one for heating and one for cooling--that can handle up to ten amps each. You can set both the temperature and the amount of variation allowed (hysteresis, for you engineers) in one-degree increments. It comes with a small waterproof temperature probe.
They apparently sell a lot of these to people who are brewing beer, hatching chicken eggs, or things like that. I could see using it to control a yogurt maker, a fridge, or anywhere you need precise control. In my case, I found that the temperature in my fridge was fluctuating more than I'd like, so I wired in an Inkbird instead of the built-in thermostat. I set it for 38° F and a 2° variation. The attached graph shows the result over a week of time. As you can see, it stayed very close to 39° (it can be calibrated, but I haven’t bothered), the only exception being when I loaded a bunch of groceries and it briefly spiked up to 43.7°. I don’t have a comparable graph from the fridge’s original thermostat, but believe me, the fluctuation was MUCH greater!
Two things that the Inkbird instructions don’t make clear: 1) It needs 12 V power to run, and terminal 1 must be positive. 2) It doesn’t supply power to your heating and cooling devices; it’s just a switch (well, two switches). Keep that in mind, and wiring it up will be straighforward.
So how did I get that neat temperature graph? I used a
Govee wireless thermometer. This is another $15 item, and this one you might actually find handy. I’ve tried many different wireless thermometers in the past twenty years, and none of them worked very well or kept on working for very long. This one does. It talks to your phone or tablet via Bluetooth, and the free Govee app does a great job of summarizing and graphing the temperature and humidity (it measures both).
I have four of these now, used to monitor and record the temperatures in my fridges (Airstream, Trillium, and car) and in my small climate-controlled storage room. They work flawlessly. If you have a need to monitor temperature and/or humidity, especially over time, this little gadget will do it.
One caveat: that Govee model is not weatherproof, so it shouldn't be used outdoors. I believe they make a model that is weatherproof, but I don't have that information handy.
