Blue Sky Controller Question January 28, 2021, 06:26:36 pm After reading through the Blue Sky manual, I determined that the Aux Out display mode is supposed to indicate the starting battery voltage. But when when I toggled through the Display Select (red) button, it showed this number which makes no sense to me. What am I missing?
Re: Blue Sky Controller Question Reply #1 – January 28, 2021, 07:41:50 pm Maybe you should read what the LD Owner manual has to say on this matter. They, the Mothership, may of not wired this option.glen
Re: Blue Sky Controller Question Reply #2 – January 28, 2021, 07:48:10 pm Greg, looks like you have 200 AH currently available in your batteries.That's a good thing.Tony R. (aka codefour)
Re: Blue Sky Controller Question Reply #3 – January 28, 2021, 07:49:12 pm You might try contacting the manufacturer of the Blue Sky 3000i.Sunforge LLC
Re: Blue Sky Controller Question Reply #4 – January 28, 2021, 08:32:58 pm Quote from: colddog - January 28, 2021, 07:41:50 pmMaybe you should read what the LD Owner manual has to say on this matter. They, the Mothership, may of not wired this option.Glen, all the LD manual (pg. 47 on mine) really says about it is that AUX-VOLT shows the chassis battery voltage. That’s why I am a bit perplexed. It may well be an amp-hr. reading. As Joan suggested, a call to the company may be in order.
Re: Blue Sky Controller Question Reply #5 – January 28, 2021, 08:41:34 pm If it is A-hrs, then the next push of the button should display auxiliary battery voltage, and the next push after that would turn the display off.Steve
Re: Blue Sky Controller Question Reply #6 – January 28, 2021, 08:55:23 pm Quote from: Steve - January 28, 2021, 08:41:34 pmIf it is A-hrs, then the next push of the button should display auxiliary battery voltage, and the next push after that would turn the display off.I was a little reluctant to go out and verify it since it’s dark now and our next storm is on the verge of arriving but I knew it would bugging me all night if I didn’t. Steve, you are correct. The next press showed 13.1 volts. Not sure why It wasn’t obvious before but thanks for your help!
