Topic: Sealing the TV Antenna Access Hole (Read 196 times) previous topic - next topic
I have replaced the antenna coax using the procedure in the TV Antenna Troubleshooting post in the Lazy Daze Companion. This post recommends to seal the hole with a good sealant.
What sealant should I use considering that the antenna connection may need to  to be accessed in the future?
Thanks for the help,
David
RV: 2002 MB
Toad: 2014 CR-V
Re: Sealing the TV Antenna Access Hole
I have replaced the antenna coax using the procedure in the TV Antenna Troubleshooting post in the Lazy Daze Companion. This post recommends sealing the hole with a good sealant.
What sealant should I use considering that the antenna connection that may need to be accessed in the future?
A polyurethane or Dicor will work fine, stay away from silicone.
Thanks for the information.
David
RV: 2002 MB
Toad: 2014 CR-V
Thanks for asking the question, David. I recently replaced my antenna and did not want to seal the coax connectors with FC 5200 since it is pretty permanent from what I hear.  I did a temporary seal with electrical tape instead.  I will use Dicor for the semi-permanent seal, maybe just cover up the electrical tape with Dicor?
Greg is close to my thought, except instead of electrical tape, I would use rescue tape.  It is a silicone base and sticks to itself but nothing else.  Stretch it, wrap the connection, then cover with whatever caulk you want.  At some time in the future, if you want to remove it, slit the caulk with a sharp knife, then a light cut through the rescue tape will leave you with a clean connector.
Ken F in NM
Thanks, Ken.  Sounds like good stuff, just ordered a roll!
