Topic: Where Is The Hidden 12v Reset Switch?  (Read 1101 times) previous topic - next topic
Mods, please do not merge this thread with the other one. I want this to be exclusively to collect photos showing the location of the switch for the outstanding floor plans. Please no discussions of anything else so as not to discourage owners that not interested in a technical discussion. We just want everyone to know where the switch is in case it ever needs to be reset. Not just by the owner, but by a tech. [Think of the hourly rate and it time it might take to locate something that they don't know exists]
Text and pictures will be transferred to The Companion. In fact, three floor plans are already illustrated there. Thanks to Jim, Tony, Mike and Charles.
They are the:
27' Mid-Bath
27' Rear Bath
24' Twin King
Needed are the
24' Front Dinette
31' Island Bed and 31' Twin Bed
27' Rear Kitchen
Plus any older models. Forgive me, I don't know them all
Re: Where Is The Hidden 12v Reset Switch?
Just checked 2014 TK
Still under refrigerator.   Need to pull out large drawer.
enclosed images
Chris - that is exactly where mine is.
Good find!
Now you know where the secret button is!
Cheers!
Tony R. (aka codefour)
Tony R
Just checked for the 12v 50 amp manual reset in my '02 30'. The search verified that I've never been able to find that 50 amp reset anywhere in the 30', even though the manual says it should be there within 18" of my batteries. I pulled both drawers from under the fridge and checked closely - nada. In the battery compartment is the sealed 12v 100 amp circuit breaker (150 amp in newer models), however, it does not have a reset button on it (that I can see). Has anyone found the mystery 12v 50 amp reset on a 30'/31'?
Hi Chris; The breaker in your photo has  a lever that will rotate out of the side if it trips. It doesn't have the button to 'set' manually. Protection from accidentally shutting off power. Originally all the parts were black. Nowadays the operating parts generally are another color. Red, yellow, are more visible.  Amazon.com: ZOOKOTO 100A Circuit Breaker, Hi-Amp Fuse Inverter with Manual...
     The 50 A. house breaker is located somewhere in the power line coming in to the converter from the battery. In 2002 it should be a small silver box, about 1 1/4" long with two power 'bolts' on top and a small black button on the side to reset it.
Manual Reset Circuit Breakers | Manual Reset Circuit Breakers Supplied...
    RonB
Here are pictures showing location of 12V "Hidden Breaker" (with reset button) for 2012 27' RK. Located behind drawer directly below wardrobe-next to couch.
Rick
2012   27' Rear Kitchen
2006 Jeep Wrangler Unlimited (LJ)
Rick
Don, our motorhome is a 1994 mid bath and the breaker is under the dinette seat closest to the entry door. The big breaker is in the battery compartment to the right of the entry door.
Jon
Finally, after 18 years I have located the mystery 12V circuit breaker. Thanks for the tip, Don. Being an electrically challenged, I was always looking for something more breaker-ish, something with a big red button or a lever on it. My question still stands regarding this breaker: if it trips, how do you reset it? Does that little black button on the front pop out to be reset? Is this an automatic reset breaker?
The photos are from a 2002 30' with the 2 drawers under the fridge pulled out. The breaker is on the floor in the lower right hand corner while facing the fridge.
Yep, the black button pops out and you push it back in to reset.
Hi Chris; Yes the little black button pops out. Pushing it back in after it has cooled down will reset it.  The letters 'BAT' specify that terminal should hook up to the battery. The other terminal with two wires; one goes to the power distribution (12v fuses) panel. The other could go to the inverter, or an electric step.  A 400 watt inverter would need about a 35 Amp breaker all by itself.    RonB
Don asked me to clean up this thread, leaving mostly only photos of the hidden 12V reset breaker. Please continue to submit photos for locations not reported yet. Don will add photos to the Lazy Daze Companion.
For those few and far between 26.5 IB units out there here is the location of the reset switch on a 2004 26.5 IB.  Not exactly easy access :D
2004 26.5 Island Bed. Gumby
2006 Jeep Wrangler Rubicon
Thanks Matt. Hard to find! Good picture. Note that it doesn't reset by itself. Presence of the black button means you would have to find this circuit breaker to rest it.
    Any idea what that gray item is directly under that breaker?      RonB
Hi Ron.
If you are referring to the flat looking, grayish area right below the switch,  that is one end of the freshwater tank. At the front of that area you can see a couple small wires connected to it. Those are the 2/3 and 1/3 water level sensors. The back of this compartment contains the hot water heater and although it is not visible in any of the pictures the water pump is also located on the floor right below the flexible duct pipe. You are absolutely right about the "hard to find" and I am not looking forward to the day when the water pump will need replacing, That is one difficult to access and tightly packed compartment! Thanks for the verification that reset of my switch is manual.
Matt
Hi Matt, Yes water tank, I should have recognized it.  My water pump is still working well, the now 21 year old Whisper-King. We picked up the motorhome from Lazy Daze 21 years ago tomorrow. Valentines day.   RonB
