Topic: Exterior electrical.  (Read 220 times) previous topic - next topic
I have a 2002 LD mid-bath. The cover on the passenger side exterior came off and will not stay on again.
Thank you,
Bill and Stephanie
2002 Mid Bath
Re: Exterior electrical.
It looks from the picture like one of the pins on the outlet cover is missing/broken.
You can try to find an identical outlet cover, but I didn't have much luck with that on my 2003.
Instead, I had to buy a new exterior outlet cover (which doesn't match the factory paint) and install it.
That exterior outlet is known for water intrusion which can lead to rust, which leads that outlet and others downstream to stop working.  If you have everything apart, I would recommend replacing the outlet and using the terminal screws for attaching the wires instead of backstabbing.
Bad rain storm, receptacles not working
GFCI Circuit Breaker Problem - Any Ideas?
Thank you Rich. Very helpful.
2002 Mid Bath
A quick Amazon search using "rv electrical outlet cover" as the search string brings up a slew of options, one of which should work.
David
RV: 2002 MB
Toad: 2014 CR-V
