Topic: Removing a Satellite Dish (Read 309 times) previous topic - next topic
The discussion on the escape hatch removal prompted my memory of this.  Bossa Nova came with a factory installed satellite dish (the manual type).  I will probably never use it so was thinking of removing it. The easiest way would be to remove the dish section only and leave the mount and roof penetration as is, if possible. I haven’t taken a close look at it yet.  Alternatively, removing the whole shebang is an option.  Any recommendations on which way to go?
Re: Removing a Satellite Dish
Andy removed one - I think.
  Hi Greg;  I'd recommend doing nothing to the antenna. There isn't much to go wrong, until you start fiddleing with it.  If you do plan on using it for TV, replace it with an autofinding dome antenna. If you need the real estate on the roof for solar panels, that would justify removing the antenna. You still have the crank up Winegard 'batwing'.     RonB.  Happy New Year, I hope you will get a lot of use out of your 'new to you' rig.    RonB
"Andy removed one"
Yes, I did, in order to make room do more solar panels. (I also removed the Winegard "batwing" TV antenna.) Removing the entire TV-sat dish and base was a fair amount of work, because its base is a big metal casting. Unless you need the roof space, as I did, I'd suggest removing just the dish assembly but not the base. I don't remember the details, but that should not be too hard to do.
Thanks Ron and Andy. I don’t really need the real estate at this point so perhaps will hold off for now.
Happy New Year!
Do any of you folks know if I could upgrade a 2010 Wingard Sat antenna (original factory install) for the newer dome type auto locating sat system?
Crank Up - Manual.
I don't think the original Wingard Sat system was ever connected or used.  All of the cables appear to be present.
I would really consider that upgrade if it didn't present an install nightmare.  Or a fortune in labor.  Price for the upgraded system is what it is.
Cheers! And a Happy New Year!
Tony R. (aka codefour)
Tony R
