First Mods on 2017 Mid Bath December 13, 2020, 09:56:07 pm Well, I did my first two mods today, minor but fun nonetheless. I mentioned in another thread that one of the Tireman valve extenders was rubbing against the wheel cover. I was hoping I could just rotate the wheel cover a little to fix it but I had to notch out the wheel cover to get enough clearance to check the tire pressure. It’s still not quite right but is an improvement and I’m going to notch out a little more later on.The other mod was relocating the sensor for the outside thermometer. The old sensor was broken and the replacement was slightly larger and did not fit inside the PVC pipe that Lazy Daze installs for that purpose. I was able to relocate the new sensor into the sewage hose storage piping which is not being used at this time. 3 Likes
Re: First Mods Reply #1 – December 13, 2020, 11:04:08 pm GregLooks like you are using 'Gator Caps' on those tire stems, nice choice. I carry a box and give them to folks. 1 Likes
