Topic: Some kitchen updates... (Read 446 times) previous topic - next topic
Updating the kitchen and bath in the 06 Mid Bath.
I’ll try to post before and after.
2006 Mid Bath
Re: Some kitchen updates...
Here’s a “before”
Rob
2006 Mid Bath
Nice job, are the tile stick on?
2018 31' TB
Very nice!
14 months on the waitlist...
Yes, the backsplash is peel and stick product but it is real stone mosaic. Home Depot.
Easy install except you really should use a tile wet saw to make the cuts look good.
2006 Mid Bath
That is beautiful.  Thank you for sharing pics and where you bought it from.
I love this too! Great work. Is there any special kind of faucet you need, or just the standard? Thanks
Sasha
2005 Mid Bath
It’s a standard residential faucet. I had to source some brass adapters to match up with the supply lines in the LD, but that was it. $8 at Home Depot for the fittings, about $150 for the faucet.
2006 Mid Bath
How much does the tile weigh approximately?
Larry,
I’m guessing about 1/2 lb each? About 6 tiles each side of the galley. Total added weight is negligible, maybe 4-6lbs total?
The vinyl plank flooring I’m putting down is fairly heavy, but there’s not but about 60 sq ft of it. Adds about 50-55lbs. Not too much weight and it’s very low on the center of gravity and spread out from the cab to back wall.
2006 Mid Bath
Weight is a trade off for me. The fixtures, wall tiles, and Flooring for a little bit heavier but if you trade up to a flat panel LED TV, new lightweight stereo,new lighter weight EMS power converter and a more modern, lightweight air conditioning unit, it’s almost a wash.
2006 Mid Bath
