Topic: Low point drains (Read 169 times) previous topic - next topic
Low point drains
‘08 MB, do most LD’s have a low point drain? Can’t find anything underneath.
2008 27' Mid Bath
Re: Low point drains
The water tank has a drain in the lowest outside compartment under the fridge (for a MB).
Aside from that and the water heater plug, there aren't any low point drains like you might find on other motorhomes.
Most owners use either compressed air (blowout the system, as described in the owner's manual) or add a winterizing kit to replace the water with antifreeze when winter comes.
The Lazy Daze Companion: Winterize
