Topic: Fuel tank replacement?  (Read 533 times) previous topic - next topic
Hi folks, does anyone know what fuel tank is a good replacement for the one on an 05 mid-bath LD? Mine is unfortunately quite rusted. Is it just a standard one for the Ford E450 or something else?  I believe it’s a 55 gallon tank, and it’s for gas, not diesel. Having trouble finding one. Thanks a lot,
Sasha
2005 Mid Bath
Re: Fuel tank replacement?
Rock auto has the fuel tank.
          Jody
You might look for a used fuel tank from the Southwest are, where rust isn't a huge problem.
Be prepared for a big job removing the old and installing the new, it is big, heavy and awkward to handle.
While you are at it, replace the fuel pump and all the hoses on top of the tanks.
Fuel pump replacement | Flickr
Make sure the old tank is completely empty, even containing a couple gallons of fuel will make it very unstable, it's like a small boat with water sloshing in its hull.
Thank you both! Wowzers they don’t come cheap.
2005 Mid Bath
Good points, Larry. I really appreciate that. I’ll look at used parts sites too.
2005 Mid Bath
Have you had a knowledgable mechanic inspect the tank and tell you it needs replacing? The undercarriage of a truck or auto from a wet or, especially, snowy environment can be quite shocking to the unfamiliar eye. Before I spent, what, maybe $1500-2000 replacing the tank I'd want to know if this is just a cosmetic/superficial problem or if the tank really needs replacing for functional/safety reasons. A mechanic familiar with what to look for should be able tell you which. And, if the tank needs replacing due to rust, what else might need attention too.
Terry
2003 26.5'RB
Gardnerville, NV
Sasha
Where does this LD live that caused all that rust?
Good point, Terry. I’m going to dig deeper on that. Thank you
2005 Mid Bath
Sasha, I went back and reread your earlier posts from when you were looking for a Lazy Daze. I saw one that said you had an inspection of this LD before you bought it. Did the inspector examine underneath the rig? If so, what did they say about the under carriage? I would ask the inspector for a refund if they didn't inspect that.
I live in the rustbelt; the photo of your tank and frame look like it was driven frequently in winter. I would suggest having the brake lines thoroughly inspected; you don't want to try  stopping a heavy vehicle with a ruptured brake line. Rusted brake lines are a frequent problem in areas that salt the roads in winter.
Good luck,
Steve K
Steve K
2003 Mid-bath
Yes indeed, Steve, sorry just seeing this. Had to replace the brake line too.
Good luck,
Steve K
2005 Mid Bath
Fuel tanks are very susceptible to rust. I had to replace my rear tank on an f250 diesel after 15 years of North Idaho winters.
