Topic: Portable solar  (Read 479 times) previous topic - next topic
Portable solar
I’m wondering if I can hook one of these units to my batteries to help out? I have a 2005 mb it has 2 t105s batteries 1 permit solar panel      Amazon.com : Renogy 100 Watt Eclipse Monocrystalline Charge 20A Voyager...    Will it work with the system I have
2005 Mid Bath
Re: Portable solar
It probably would work, as long as you understand how your 2-6V batteries are wired together to act as one 12v battery.
I would caution you that suitcase type portable panels have a number of disadvantages (storage, theft, positioning, inefficient charge controllers [PWM vs MPPT], cost per watt, and so on...) and most people would prefer additional roof mounted panels if at all possible.
Re: Portable solar
Hi Robert;  If your purpose is to have a panel you can place in the sun, while you are parked in the shade, it will work. But you'll need a longer cord than 20 feet. Then there is that theft situation. I expect that it would 'walk away' pretty quickly.
   Your 2005 should have one 85 watt, 36 cell, monocrystaline panel and a HPV-22 MPPT controller. Two panels for a total of 170 watts is within the capabilities of the Heliotrope controller.  Your best bet would be to add another panel near the one you have. (on the roof) I'm not sure where, or if, you have a combiner box for that one panel.   RonB
Re: Portable solar
Hey Robert,
I regularly use  a Renogy Eclipse 200 watt portable suitcase case direct connected to my  two house 6 volts for charging and it works greats. I also carry 2- 25' extension cables to maximize placement flexibility. I do the majority of my camping in the PNW so there is frequently  an abundance of greenery shading that renders my 85 watt roof panel pretty useless or nothing more than a trickle charger much of the time so these additional panels are a must for me.  I've previously used  two other panel brands and the Renogy panels really shine performance wise in comparison. As others have mentioned, do be careful with security.
2004 26.5 Island Bed. Gumby
2006 Jeep Wrangler Rubicon
Re: Portable solar
If I may post my solar panel built.    Homemade Portable Solar Panel Built
Background --  I built this  system to teach myself solar basics.    Over the last year I have 'upgraded' it with a larger solar panel and MPPT controller then added a Jackery 1000 to the mix.   In a few weeks I'll be testing the whole system during a week long camp on the coast of Oregon.
To answer your question directly yes you can add more 'portable' solar panels but there are a few issues that need to be addressed.
glen
Re: Portable solar
For what it's worth, I've been using portable panels for years to provide supplemental power in wintertime and in shaded locations. I haven't had one stolen yet, but maybe I've just been lucky. For the most part I've used "just plain" (no built-in controller) panels such as inexpensive Renogy 100-watters, propping them up with a cheap folding stool to get a better angle. I feed the output into my rig's solar controller in parallel with my roof panels (matching voltage, of course).
With my Airstream I carry two cables: a 25' one and a 10' one, made from Ancor 10/2 (AWG 10) marine cable. When feasible, I use the shorter cable, which minimizes voltage drop, but if necessary I use the longer one or even (rarely) both. I've even connected two 100 W panels this way, paralleling them at the panel end with MC4 Y-cables.
With my Subaru Outback (which has a solar-powered refrigerator), I have a 45 W panel mounted on top of my rooftop storage box--it was the largest I could fit there--and use a 50 W Renogy controller-less portable panel with a folding support frame to provide supplemental power if parking the car in the shade. (Both feed into a Victron solar controller, which charges a group 27 AGM battery.)
For that portable panel, because the 2.7 amp current is so low that I don't worry too much about voltage drop (1.6% at max current), I use a cable made from an off-the-shelf 25' 12-gauge outdoor extension cord. I just cut off the plug and outlet ends and crimped on MC4 connectors. For higher panel wattages, though, the 12-gauge extension cord would impose more voltage drop than I'd be comfortable with.
Re: Portable solar
Our motorhome doesn't have a roof mounted panel so I bought the exact set that Robert is using. For us, it works great, I did have to build an extension cord for it. I wired in solid on the battery with a heavy duty plug and used the same plug manufacturer on all other ends so I have several options for wiring. I especially like the no holes in the roof.
Jon
Re: Portable solar
 "I feed the output into my rig's solar controller in parallel with my roof panels (matching voltage, of course)."
Andy, could you explain this process a bit more thoroughly for this non-techie?
Re: Portable solar
Theft Issue - If you just need more solar and don't need to extend the new panel out away from the RV to get the sun, you can always just set it up on top of the RV.  I have a Zamp 170W panel and we do this all he time in the truck camper world.  You can use the legs and aim it south and from the ground, no one can tell that it's not attached unless they watch you set it up.  Several of my friends just lay it flat.  It's then out of sight and there's usually just a little drop in output.
Greg
2006 26.5' MB
Re: Portable solar
"could you explain this process a bit more thoroughly...?"
Sure! Power from the roof panels comes down into the compartment where I have the solar controller mounted, and connects with ring terminals to a pair of PowerPosts. From there, wires to the positive and negative "PV" inputs of my solar controller. Another cable goes from the PowerPosts to a short lead dangling outside the RV, ending in MC4 connectors--the kind used to connect most solar panels. From there, the MC4 extension cords I made up go to the panel or panels on the ground.
"matching voltage, of course"
To clarify: with my Lazy Daze and my 27' Airstream, I had the roof panels wired in series pairs, so the voltage into the solar charging controller was about 18 V + 18 V = 36 V. Thus, when using additional panels on the ground, I used a pair of panels wired in series to match the 36 V from the roof panels.
In other words, when using both roof panels and ground panels, whatever the voltages are must match, because the two sets of panels are connected in parallel at the PowerPosts.
If I had my roof panels wired in parallel with each other for 18 V, as many RVers do, then a single 18 V panel on the ground would have been a good voltage match. If I needed more power and wanted to use two ground panels along with the parallel-connected roof panels, then an MC4 "Y" connector would let me connect my ground panels in parallel with each other, thus matching the 18 V from the roof panels but adding extra amps.
Re: Portable solar
Andy, what is your opinion about the pluses and minuses of parallel and series when setting up many panels?
   Thanks
             Karen~Liam
                98 ~ MB
                  NinA
1998 ~ MB  WanderDaze
Re: Portable solar
We use a plain old roof type solar panel with 20 ft mc-4 connector wires and a weatherized mmpt controller as a portable solar option for our small Travel trailer. No theft problems at various state/federal parks here on the east coast, from Quebec to Florida, but it sounds like campground theft is a bigger problem in general out west. It great to be able to maximize available sun.
