Taking awning off - freestyle September 08, 2020, 06:59:48 pm One of our projects has been to remove our awning. We use sail cloths instead. We will be donating our awning to Melissa.We have a Freedom II from Carefree of CO. I don’t know if it is original or was added with the flurry of items done right after it was purchased (or sometime later).I found https://www.carefreeofcolorado.com/documents/Freedom-WM-Installation-Manual.pdfWhich is the closest one to our style.This matches what we see - 3 screws we think we can access if we open up the awning.Plates with a long row of screws above the awning.If we reverse the install instructions, we would take off the bottom brackets for the vertical supports, unfurl the awning, take out the 3 screws, twist the awning 90 degrees and lift it out, then take off the back brackets and patch holes of course.Anyone take off this model (or a similar one) - does this sound right. Any tips?Thanks Jane
