Topic: foggy windows (Read 2073 times) previous topic - next topic
Re: foggy windows
Reply #50
I just had mine done at ProRV right outside Dallas Texas.  I posted a lengthy description of the process and experience.  I would recommend them to any LD owner.  I considered going the RV Glass Solution route in Florida, but it took the main office 3 days just to answer the question if they can do them.  I had to send them pics for obtaining estimates.  They basically have expanded and bought out some local operators in Florida and other states.  I'm not so sure those places will provide the same level of service as the original Cogburn or Phoenix facitilites.  I would imagine it's all about the tech's capability who does the work.  The estimated cost for repair from the RV Glass Solution main office, was twice the estimates from Suncoast and ProRV.  Given the LD reviews and the need to be patient and take your time dealing with the Inner seal and aluminum siding, I opt'ed out of the Suncoast route.  Suncoast's reviews are all over the map.  I address several technical challenges of dealing with our windows in my writeup.
See my write up in the other forum "Lazy Daze Info & General Discussions".  Foggy windows are discussed in several places.
foggy windows
ProRV is located in Colleyville, Tx.  Ask for Dawn Cass who is over that Glass repair department.
Robby
2004 Mid Bath
Re: foggy windows
Reply #51
Suncoast is variable as the tech's turnover every week.
Most RV windows are easily removed. We all know LD does not intend moisture to enter and seals them quite well. Suncoast expects the techs to complete a rig quickly, so pry bars get used and the rig gets damaged.
Re: foggy windows
Reply #52
I had a 97 LD that I sold a couple years ago and there was no fogging in any windows. Is it possible the older windows were of superior construction or was I just lucky?
Re: foggy windows
Reply #53
The fogging only happens in dual pane windows with an air space between the panes.  97's didn't have them, so no fogging.
Linda B
Green 2021 RB
2022 Ford Maverick toad
Re: foggy windows
Reply #54
Well that explains that.  :D
When did dual pane windows start in LDs?
Edit: Answered my own question thanks to Andy's blog.
Windows
"One of the big attractions of a Lazy Daze coach is the number and size of windows. In addition, they have always been deeply tinted so that although occupants can see out, folks outside can't see inside in daylight. Prior to 2003 models, the windows were of a double-pane construction with a tinted film between them, but there was no insulating air space between the panes. Beginning in 2003, LD started using a true insulated window, with improved insulating qualities. These windows greatly reduce wintertime condensation."
 With all the fogging issues of true thermal pane in a moving vehicle maybe the pre 2003 way was better.
Re: foggy windows
Reply #55
Except the laminated windows can crack. We haven't been able to find a local glass provider that has a tinted laminate that is dark enough to replace ours. We have a crack in one side of the laminated glass in a rear window.  It doesn't affect safety so we live with it.
Sand Castle (Theresa & Everett) Surfside
01'  26.5 Mid Bath,   2018 31IB
Michigan born and starting to explore the US with my  spouse and our furry friend. Enjoying joining LD group rallies.
Re: foggy windows
Reply #56
Theresa,
I *think* Hehr is the manufacturer of those windows.  There is a Hehr glass plant in Michigan, and window plants in MI and IN.
Window Plants   Worth a try.
Linda
Linda B
Green 2021 RB
Re: foggy windows
Reply #57
Same here, it doesn't leak, just looks bad, I can live with it.
Jerry Galang
Meridian, ID 83646
Re: foggy windows
Reply #58
Theresa,
Linda
Thanks Linda,
I didn't know there was a Hehr Glass plant that close to us.  I sent them an email requesting any info they could provide. I will report back.
Re: foggy windows
Reply #59
Hi, Linda B!  Have you picked up your LD yet?
Theresa, I just wrote to Hehr too -- they are near Saginaw - Chesaning, I think. I was asking (tho acknowledge probably not..) if they would sell a replacement rear window unit to me I could take down to those guys in Elkhart to install. However, I emailed them (RV Glass Solutions/Elkhart) the same day -- and haven't heard back yet -- so most likely they will want to buy from Hehr and mark up + install labor.
If I make any progress on this, I will post.
MJB
Marcia Boynton
2005 26.5 RK
Adrian and Northport, MI
Re: foggy windows
Reply #60
Identical topics from 2 boards merged here.  Please do not start multiple topics for the same thing.
