Topic: Fuse panel green light - Blinking versus solid? (Read 110 times) previous topic - next topic
So, in the picture below, you'll see a green light bulb on the right-hand side.  Sometimes it blinks once every 15 seconds or so, but I've also seen it stay solid.  What does blinking versus solid mean?
Re: Fuse panel green light - Blinking versus solid?
Looks like your rig is outfitted with a Progressive Dynamics converter. I updated the ancient converter in my 2003 TK to a PD converter and the manual details the modes that are indicated by the blinking LED:
BOOST MODE – Indicated by green LED remaining on. The output voltage is 14.4VDC to rapidly recharge the
battery up to 90% of full charge.
NORMAL MODE – When the battery is between 50% and 90% charged, the green LED will flash once per
second. When the battery has reached 90% of full charge the green LED will flash 2 - 3 times per second. In this
mode the output voltage is 13.6VDC and the converter is safely completing the charge of the battery.
STORAGE MODE – Indicated by green LED flashing every 6 - 8 seconds. In this mode the output voltage has
been lowered to 13.2VDC, the RV battery is fully charged and the converter is maintaining the charge.
2003TK
Perfect...Thank you very much!
