Topic: New sewer hose (Read 649 times) previous topic - next topic
New sewer hose
Our sewer hose is old and worn. Replacing it before it leaks seems like a good idea.
The existing 15' hose is a Valterra hose with twist-on fittings, it might be the original.
Many of the replacement hoses have fittings on both ends and will not fit into the Factory storage due to the end being too wide to pass into the storage tube.
Other hoses do not compress enough to fit the storage, 45" is the maximum length, when compressed.
So, what hoses are others using and will they fit into the Factory storage tubes.
Re: New sewer hose
K.I.S.S. for me - Camco 10' Super Heavy Duty sewer hose.  I inherited it when I bought the RV, so I didn't exactly chose it.
I think I took the bayonet fitting off of the previous hose and transferred it to the new hose.  Maybe it wasn't original?  It's held on by a hose clamp.  It's a black 45 degree fitting that barely fits in the compartment door when oriented in the correct direction.
I very rarely use full hook ups, an this works for me at the dump station and fits easily into the storage compartment.
RIch
'03 MB in NC
Re: New sewer hose
Similar to Rich, I used a 45 degree bayonet fitting (which I think came originally from LD) and some Prest-O-Fit hose fittings.  The slip-on fitting attached to the end of the hose could slip into our LD's hose storage and the 45 degree bayonet  would just fit behind the storage door.  I don't recall if we had a 10' or 15' hose.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Re: New sewer hose
For more years than I can remember (long before owning a LD) I have always used the Presto-Fit BlueLine sewer hose system. I never had any issues with the slip-on fittings coming loose and they were easy to undo with a twist. The kit comes with a coupler to connect an additional hose if needed, an elbow to use at the dump portal, and a four hook twist on connector at the RV dump valve. In addition to the above, I also use a Valterra RV Hydro Flush 45º clear plastic adapter at the dump valve connection to easily view when the water from the sewer tanks are running clean(er). If need be, I can attach the dump station hose (or mine) to this connector for an additional rinsing of the hose when finished dumping. I also carry a foam rubber sewer seal only for campgrounds that have that requirement.
Best of all the 10' up to a 15' hose will EASILY fit in the LD hose storage housing even with the 4-hook connector in place. To keep the hose secured behind the storage door, I added a short bungee strap across the end of the hose (behind the door). The extra hose in the kit I stored in a storage container in the LD storage compartment above the sewer drain pipe (rear bath model).
Web sites:
BlueLine:  <https://www.prestofit.com/BluelineRVSanitation.html>
Valterra: <Valterra RV Hydro Flush 45º | Camping World;
Rubber sewer seal:  <Camco Foam Rubber Sewer Seal | Camping World;
All items are available several places even though I referred to the Camping World web site that does sell these products.
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
Re: New sewer hose
I've always used Valterra hoses and fittings; Valterra used to offer a kit with hose and E-Z Coupler twist-on fittings, but that particular style is no longer available. The E-Z Coupler now has attached fittings that are bulky and can be difficult to use. My current set(s) of hoses and attachments are assembled from fittings on these pages:
Couplers, Fittings and Adapters Archives - Valterra.com
Sewer Fitting Archives - Valterra.com
The hoses that I use are Valterra, but previous incarnations of this one:
Quick Drain Hose, Heavy Duty, 10′, Blue, Boxed - Valterra.com
I also carry a full set of spare hoses and fittings and a 5' extension hose with appropriate fittings. This may be overkill for some, but sewer hoses and fittings are an essential pieces of equipment, IMO, and if they're damaged or lost, the resulting scenario may not be pretty.  :o
YMMV, as ever.
Re: New sewer hose
YMMV, as ever.
When my original was preemptively replaced last year, I replaced it with the 10' Valterra you mentioned (it looked like the original) and added a new attachment fitting which fit better in the holder. I don't have anything on the business end, usually just sticking it in the sewer hole and watching carefully. I carry a spare also.
Re: New sewer hose
When I had the Kwikee levelers installed, I lost some of the storage space for the hose. The end of the storage corrugated hose had to be shortened.  The 'cheap' hoses with the thinnest material shorten up the most. So that is my dump hose, with no fitting at the end.  Harry Wilson had the forethought to have the factory put in a second hose storage space on his MB, so I copied that and put a 6" solid ABS (foamcore), about 6 feet long pipe, across the back underneath the rig. It holds the thick material 'better' hose, with a park connection fitting at the end. The 'elbow' still won't go into the tube, so it is stored in a ziploc in the storage compartment above it. Each hose is a spare for the other. A TK just doesn't have much spare room.
      I haven't seen any parks yet where I needed that foam gasket, I don't carry one (yet). I don't leave the hoses connected, except to dump.  Some parks that I have been in, require a 'slinky' support for the hose. I don't carry one of those either.   RonB
Re: New sewer hose
Can I ask what the gray box w/ the dates written on it is?
2001 MB
Re: New sewer hose
Larry, I don't have enough connection speed to search for links for you.  With that said, I replaced my hose a few years ago.  I bought a hose that was about 10 feet long and cut off and discarded the bayonet fittings on the ends.  I removed the old hose from the original 45 angle fitting, put a little caulk on the fitting and worked the hose onto the fitting.  I added a band clamp, because I did not want to take the slightest chance of the hose slipping off or leaking.  I have no problems fitting the 10' hose in the storage space.
Ken F in WY
Re: New sewer hose
I do not remember replacing it, it may be the original hose.
Since the old hose has worked fine for our usage, I'm going to reuse the bayonet fitting and buy a 15' Camco HD hose.
Amazon.com: Camco Durable High Tensile Strength Vinyl Sewer Hose with Steel...
For $12, it's hard to pass up.
I want a 15' hose, a 10' hose works most of the time but occasionally, an extra 5' would be handy. We don't have the room to carry an extra 10' hose.
A 45 degree fitting for sewer connection threads on the bare end, along with a foam donut, it doesn't get used often.
Re: New sewer hose
For what's it's worth--I don't use the hose storage provided by LD. A number of years ago, I screwed three large hooks into the plywood backing of the cover for my "spare tire" compartment. My hose is placed over the hooks with the ends hanging down.  Easy to get to, and a use for "dead space"
George & Jo Ann
99 MB
Nashua, NH
George & Jo Ann
2017 MB
Re: New sewer hose
Mine packed it in after Quartzite this year. Replaced with THIS   I first bought the 10 footer, but realized it was too short.
dog Zeke
Re: New sewer hose
That's why I wanted a 15' hose. The Prest-O-Fit hoses were interesting but only available in 10' sections.
I looked at the Valtera hose but its's only 8-mil thick, the Camco I ordered is 15-mil thick, a mid-range hose. We do not need a heavy-duty hose, it's rarely left outside and when dumping at home, a macerartor and a dedicated 3/4" hose are used.
Realizing I was overthinking this, replacing with the same hose, duplicating what has worked for 15 years or more seems logical.
At $12, if it is a mistake, it's a cheap experiment
Someday, we may get to use it..
Re: New sewer hose
Hi Henness;  That little box was the transmitter for outside temperature, to my inside temperature monitor. Accurite I think.  Out of the way, not too affected by engine heat. AAA battery pair lasted about two years each change. Was in the picture.I have a fancier temperature monitor now.     RonB
Re: New sewer hose
I ordered the one Mike C recommend when I asked.  The Blueline Ultimate. I like it.
Steve and Jill, Steve posting
1999 26.5 Mid-Bath
Re: New sewer hose
Larry said:   "I want a 15' hose, a 10' hose works most of the time but occasionally, an extra 5' would be handy."
I agree. Some time in the past one of my 10' Prest-O-Fit (POF)  hoses wore out and I bought a heavier mil 20' hose which (of course) wouldn't fit in the LD hose storage tube. I just removed the end of the new hose and stuck the old POF pushover quick connector onto the new hose clamping it with a stainless hose clamp. I then inserted that end with the connector into the storage tube to see how much would fit with the twist on fitting at the other end. That is where I cut to shorten the new hose. It was just over 15'. That modified hose has lasted many years and went with the new owner when I sold the LD last December. I will repeat this with the new coach during my modification sessions this coming winter.
2004 Born Free 26'
Re: New sewer hose
The Valterra hose linked in my first post is 15 mil; didn't see an 8 mil hose?Quick Drain Hose, Heavy Duty, 10′, Blue, Boxed - Valterra.com
When searching, I looked at this one.
Amazon.com: Valterra Products, Inc. D04-0120PB 10' Blue Standard Bagged...
Many of the heavy duty hoses are heavy, thick and will not go into the storage tube.
Re: New sewer hose
Another reason that I prefer the Valterra EZ-Coupler fittings (the red ones) is that the fitting that attaches to the tank outlet has four "prongs" instead of two.
Re: New sewer hose
I was attracted to the Prest-O-Fit system but the lack of a 15' hose eliminated it.
I liked the idea of being able to easily attach a 90 degree sewer fitting, for RV park usage. I may still buy an adaptor and see it it can be adpated to the Camco hose.
The $12 hose will work fine, as it has for 18 years. This isn't rocket science.
Hoping to escape home in a week and a half…if these reservations are not canceled.
I don't know if we will remember how to camp, its been four months, the longest we have ever been home in over 40 years.
It should be like riding a bicycle, you never forget.
Re: New sewer hose
Glad you are finally able to get away, Larry.  I saw this article of a recent study that ranks the risks for COVID-19 by certain activities and was glad to see that camping is considered a low risk activity. Have fun!
https://www.foxnews.com/health/texas-doctors-rank-activities-posing-greatest-risks-for-contracting-coronavirus
Re: New sewer hose
I noticed that while the scale is 1-10,  highest score is a 9.  Are they leaving room for expansion?
dog Zeke
Re: New sewer hose
Since you're talking sewage hoses, Did Laze Daze fix the sewage system where you have two outlets?  Like one for black tank and one for the grey?
I hate having to hook up twice!
Re: New sewer hose
It depends on the floorplan and if both tanks are on the same side of the rear axle.
What floorplan are you interested in?
Re: New sewer hose
Reply #24
I’m guessing this would be a 10, Joel:
Here’s Why You Shouldn’t Go To A ‘Covid Party’
But the way, we are in your neck of the woods at the moment. Staying in Folsom and took a drive up to the Apple Hill area today!
