Topic: Awning bracket  (Read 449 times) previous topic - next topic
Awning bracket
Trying to find this part to replace the broken bracket for my awning arms to fit into.
Any help would be much appreciated. see picture below
1993 MB
2006 Honda CRV
Re: Awning bracket
1993 MB
1993 MB
2006 Honda CRV
Re: Awning bracket
It looks like those older style wall brackets for the Fiamma awning legs may have been superseded by a newer style, Fiamma #98655-728.  I have no clue if the mounting holes would line up.  You may want to call LD to see if they have any of the older style parts left in stock.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Re: Awning bracket
The factory has them, or at least, they did 2 years ago when I replaced one.
Ken F in WY
Re: Awning bracket
I just replaced my awning and have two of these, didn't throw away.  I'm in Corona, Ca. how can I get them to you.
FYI,  new Fiama brackets have the same hole pattern but mine are free!
2001  26 1/2  Rear Bath
2001  Jeep Wrangler
Re: Awning bracket
I broke my awning brackets and purchased some replacement brackets from Fiamma. Though the screw holes line up the new brackets don't hold the awning feet properly (completely). I have to keep a very close eye on the awning and lower it if the wind gusts a little too much.
Please see the attached pics.
My wheels:
2012 Jeep Liberty
Re: Awning bracket
If you installed the spacers and don’t over tighten the top screw, the top of the bracket pushes down to cover
The foot of the arm. They are a little tough to pull back up but a little dry lube helps. Better tight than loose, but
They won’t fall “up” 😎👍🇺🇸
2001  Jeep Wrangler
Re: Awning bracket
 I did install the spacers and kept the top screw loosened (or it would tilt up in a weird position).
I'll play around the screws some more to see if I can get top slide to work for me. Thanks for letting me know that they actually can work!
My wheels:
2012 Jeep Liberty
Re: Awning bracket
Webebad, if the bracket in your first post is the 'broken' one because of the missing upper locking post, I would have just replaced it with a stainless 10-24 panhead screw, about 2" long, and a stainless nylon locknut. If you haven't tossed them, that would still be an option.
Re: Awning bracket
Thanks for all the help everybody. Invaluable advice.
I was able to replace the parts with new brackets from the Mothership. All good now.
1993 MB
2006 Honda CRV
