Topic: I Found a 2004 To Look AT (Read 203 times) previous topic - next topic
We are going to look at it tomorrow.. It's a couple hours away so road trip for the wife and I...
Being this is the very first time I have looked close at one is there anything I should look out for? I will not be buying just getting my feet wet....... Thanks LeeB70
It's a 30ft with split rear beds........they want $30k for it 35,000 miles..
Wanna-a-Be
LeeD70
Re: I Found a 2004 To Look AT
The biggest problem areas are window and end cap leakage. Check carefully under each window, paying close attention to the rear window, looking for any signs of leakage around the windows and in the rear interior corners.  Also check the rear exterior cargo compartments, in the rear corners.
Look for end caps the have pulled away from the body, the rear end caps are the most trouble-prone and the source of potential leakage and rot.
Check out downgrader's repair thread to see what you are trying to avoid.
The roof, vents and exterior window frames should have been resealed by now, something else to check.
Happy hunting
Thanks for the tips..... I'll check out the caps.....
LeeB70
Wanna-a-Be
LeeD70
