Topic: How is overhead mattress attached? (Read 197 times) previous topic - next topic
Planning and thinking.....
Is the overhead mattress fabric cover connected to the wood base completely or is there a lip where a fitted sheet could fit under it?
And while I'm at it, are the sofa cushions separate or are they all attached together, bottom attached to back, etc.?
Linda
Linda B
Green 2021 RB
2022 Ford Maverick toad
Re: How is overhead mattress attached?
Linda
I can't speak to the mattress as we have a 31 TB but the couch back cushion is separate from the bottom cushion....the back has Velcro on it to attach to the wood backing of the sofa
Bill
2013 31' Silver Twin Bed
Semi-retired 6/21....
The overhead mattress is not connected.   It's easy fit sheets under it.   It is also a great storage place for flat things like cutting boards, laptops, and steps that fold flat.
Keep in mind you will most likely need a piece of foam on the mattress unless you prefer a VERY firm sleep surface.   Picking the right foam type and thickness can be tricky depending on how fussy you are about such things.   If possible buy from a store that will accept a return/exchange.     Frank
plan B - 2023 Travato
Frank and Bill,
thanks for the info.
Linda
Linda B
Green 2021 RB
