Topic: Broken MB Bathroom Blind (Read 205 times) previous topic - next topic
The mechanism that opens and closes the blind in our midbath bathroom window is broken.  The rod is still attached, but turning it does not open or close the blind.  We are thinking we may need to replace the entire blind.  Does anyone have any suggestions for doing this?  Is the blind a common size that might be available at Lowe's or Home Depot?  Or would it be best to just contact the factory for a replacement?
Thanks,
Paul
Paul
2010 MB (2011-present)
1994 Multiplan (1997-2010)
Re: Broken MB Bathroom Blind
Unless the blind has other problems, the internal parts can be bought. Or a cheap donor blind can supply the part you need. Its been a long time since I repaired some but I remember it was pretty easy.  RonB
As a property manager we are repairing broken blinds all the time.  That part is particularly susceptible to becoming brittle.  Take the entire unit down and take it apart.  Once you have the actual part you can do a search for blind repair parts.  If you damage the unit beyond repair, it is simple to order a new blind.
The blind can be fixed or replaced.  You can find cut to length mini-blinds at any home improvement store.
You can also remove the blind.  Fixing frosted window film to the glass in the window lets in the light without letting outsiders look in.
'03 MB in Nc
Parts for nearly all blinds are available at FixMyBlinds.com.    There are thousands of drawings/photos of a zillion parts.  I've fixed many blinds with their parts and instructions.  Good luck!
JuliW
Minden, NV
Juli W.
Former owner 1994 mid bath,  2006 26.5'rear bath
Good site, Juli; thanks!
Thanks a lot, all. Loni saw this thread and now I have work to do! ☹️  — Jon
