Topic: MCLUBE SailKote High-Performance Dry Lubricant, 8 oz (Read 172 times) previous topic - next topic
Good morning,
One items I was getting ready to order this morning was the dry lubricant for the interior windows slides.
Is there any other items from this site that I should purchase at the same time for maintaining the new to me LD?
Do you use this same product on the outside of the window seal to keep it conditioned to prevent drying and shrinkage?
2000 MB,
Kimberley from Kansas
2000 Mid Bath
Re: MCLUBE SailKote High-Performance Dry Lubricant, 8 oz
Kimberly,
McLube Sailkote is a good product and I use it regularly for locks and sliding window tracks.  As Joan suggested, 303 is also great stuff and an excellent defense against the damaging effects of ultraviolet light on plastic and other parts.  I don't use 303 inside the Lazy Daze since UV is rarely a problem, but it is great for plastic parts on the outside of the Jeep and motorcycles.
Harold
2014 27 MB
Happy wife=Happy life
Thank you Harold and Joan.
Kimberley
2000 Mid Bath
Be cautious when applying the Sail Kote (or 3-in-One window track lube) to the window tracks; clean the tracks well first - I use a toothbrush and white vinegar and water; dry them well - and use the "straw" (on the container or separate) to apply the lube directly onto the bottom of the window track. The glue that holds the fuzzy strips on the sides of the window tracks can come loose if the track lube gets on those surfaces. I also suggest covering the back(s) of the couches or anything else that may in in the way of any "stray spray".
I have used McLUBE SailKoe for over ten years, originally suggested by sailor Bill Atkins, an old member here. It's excellent stuff but very expensive.
A cheaper variation for the window tracks is using a dry Teflon spray lube. I buy this at HD.
Blaster 9.3 oz. Advanced Dry Lube with Teflon-16-TDL - The Home Depot
It doesn't last quite as long but is still a good product.
303 is THE product to use on rubber and vinyl products.
